Catalytic Converter bad causing drive bat to fail
Discussion in 'Gen 2 Prius Technical Discussion' started by gordonmcds, Jun 1, 2018.
  1. gordonmcds
    gordonmcds New Member
    Auburn, WA
    I replaced my drive bat last year in April through Greentec Auto. It just failed again. They said that the reason why was because of the P0420 code and I need to replace the catalytic converter. Anyone heard of this? The bat is covered under warranty but they caution that because the cat is not performing correctly, the gas engine is putting more strain on the bat. Sounds flaky to me. Seems that the gas mileage would decrease because the gas engine is not operating efficiently. Not sure why this would put extra strain on the drive bat as the engine only uses the hybrid motor to assist not as a primary drive. Are they right?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    If the cat converter was clogged badly enough to keep the engine from starting, or running decently, I could see it being an issue.
    I drove my white 2005 for about a year with an amatuer rebuilt battery with the 420 code and never had a problem, until it was run off the road by an SUV, that car was still averaging 48-51 mpg.
    If you had 'engine fail to start'/ engine weak/etc codes along with the 0420 code, then maybe I could believe the cat was clogged badly.
    Did they tell you what the actual fault code was?
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    49,375
    rebuilt battery companies will use any excuse not to fulfill warranty claims. you're lucky they gave you another.
    does your car pass emissions?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    NO.
    But if the CAT is going bad you need to get that fixed TOO.
    It may be putting some additional "strain" on the engine......but not the battery.
  6. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    I have heard of that too, but don't know exactly the dynamics. I don't think the catalytic converter has any impact on the battery
  7. TMR-JWAP
    6,193
    5,891
    Columbia, SC
    Keep in mind that a severely damaged/clogged cat can reduce engine power significantly, which in turn, can cause the HV battery to be loaded/cycled quite a bit harder than usual. Most "refurbished" batteries are already a bit sketchy, so there's no telling how well they'll handle the additional cycling/loading.
    Now, that being said, my white 2005 (may it rest in pieces) had a P0420 the entire time I had it (about a year). That puppy had 280k + miles and was still banging out great mpg every tank. That one had an original 2005 HV battery (removed from my blue 2005) which had one failed module replaced with a 2006 module by the previous owner and his son... It never had a problem.
