Catalytic converter exhaust coolant leak repair recycle gen 4 prius
Discussion in 'Gen 4 Prius Technical Discussion' started by doctorman, Jul 8, 2024 at 1:11 PM.
  1. doctorman
    doctorman Member
    203
    34
    NY 11020
    Had a coolant leak in my car converter 2016 Prius and had it replaced
    What can I do with the old part?
    Is the leak repairable?
    Do I get any money for the cat precious metals? Who woul I go for recycling that?
    Thanks
    49,402
    they had to replace the whole cat?
    look around for metal recyclers, i think they buy them.
  3. Mendel Leisk
    38,669
    It's too bad they don't have a bolted joint between the Exhaust Heat Recover portion and the Catalytic Converter portion, of that single piece. Or at least Toyota could author a cut-and-weld procedure of some sort.
    Hang onto the old piece? If your Cat ever goes you'd have a spare, that someone could weld in.
