Catalytic Converter Replacement - 2008 Prius - OPTIONS?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jpk1102, Oct 19, 2015.
  1. jpk1102
    jpk1102 Junior Member
    2018 Prius
    Catalytic converter on our 2008 Prius needs replacement. Dealer has quoted $2300 which is out of budget. Are there other options in the Houston or Dallas/FW Texas area? Suggestions?
    The catalytic converter in our 2008 Prius needs replacement. Dealer quoted $2300 which is out of budget. Are there any other options in Houston or Dallas/Ft. Worth Texas area?
    Mod note: Separate threads on this merged, please report the postmade in the wrong forum, don't repost yourself. Thanks.
    #1 jpk1102, Oct 19, 2015
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Muffler shop? I had one replaced on a Nissan Frontier a few years back. Someone did a five finger discount on the original one, right in my driveway. They simply unbolted it. I never knew what happened until I went to start the truck up. Boy, was it loud. I found the shop which was in Humble, TX by doing a "google" search. Best of luck to you.
  3. jpk1102
    2018 Prius
    Thanks Dorunron, I realize I posted this in the wrong forum so have reposted in 2008 area. Are you in Houston area?
  4. Mendel Leisk
    38,726
    Wait what: they stole your catalytic converter? Oy!
  5. dorunron
    3,318
    1,103
    Houston, TX
    Yes, they simply unbolted it and took it. I had no idea of the theft until I went to start the truck one day. It was very loud. Either someone wanted it to recycle for the precious metals inside or they needed one for their Frontier. Either way it was gone, and I never knew just when it was taken or who got it. Insurance covered the claim, less a $250 deductible. It cost a little under $500 for the repair. I sold the truck later to my former mechanic. Last time I saw him he was still driving it. That was a few years ago.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  7. dorunron
    3,318
    1,103
    Houston, TX
    Yes, northside close to Mattress Mac.
  8. JC91006
    16,482
    8,400
    This CAT will work nicely for around $100
    Purchase on Amazon
    Magnaflow 99205HM Universal Catalytic Converter (Non CARB compliant)
  9. knettle3
    knettle3 Junior Member
    38
    zachary
    I ordered a direct fit Cat and resonator assembly from Amazon (2008 Prius with 210,000 miles) several months ago due to the PO420 MIL and needed to get car inspected. In Louisiana, they wont even inspect the car if the MIL is on, unless you are expired. They will then issue a rejection sticker, which is good for 20 days, I think. The Cat I bought is made by Walker Automotive, and has a lifetime warranty. The Cat pipe (which is 2 converters- one small and one bigger), the resonator pipe, 2 donut gaskets, and replacement bolts totaled less that $500, with free shipping. Bolted up to my car precisely without welding-- the resonator and cat pipe are slip-fit. I used 2 U-bolts to join them. I cleared the code, and the light remains off to this day. We will have to see how this option stands the test of time!
  10. bkcriz20
    bkcriz20 Junior Member
    53
    Queens
    1. I'm actually thinking of going the same route. Been looking through Priuschat to see if someone bought Walker Cat Converter and how it's been holding up. How you had any problems with Walker yet?. Is your Prius still loud or is it louder than before your Cat Con needed to be replaced?.
  11. toobz4this
    toobz4this Junior Member
    North Carolina
    Do you have the part number or link to the actual part that you ordered? My Toyota dealership told me it would be $2200 just for the part. If I were still in Indiana, this wouldn't be an issue. But I moved to NC and they have vehicle inspection here.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    @toobz4this
    You can use a aftermarket replacement. I've replaced one in a 2005 and one on a 2006 this last week. They're available on ebay for a few hundred dollars. If you want to road trip to Columbia, I could help you out.
