Catalytic Converter stolen and replaced, now have A/C issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Banshee, Feb 28, 2022.
  1. Banshee
    Banshee Junior Member
    San Diego
    Hi all, a hopefully quick question.
    My catalytic converter was stolen last October and was replaced, but I noticed a couple weeks later that when I tried to use my A/C, it's only blowing hot air. It was working just fine before then.
    I'm wondering if the A/C could have been damaged when the converter was stolen? Or did the A/C just decide to fail at the same time?
    Thanks!
    mr_guy_mann likes this.
  2. JC91006
    16,674
    8,519
    Did you install an Oem original Toyota catalytic converter? The AC should not have anything to do with the Catalytic converter.
    What's the car's history?
    SFO likes this.
  3. JahT
    JahT Member
    145
    76
    I assume you mean that the AC is not getting cold anymore? Did you notice it getting less and less cold? Or do you notice it being colder on the passenger side than on the driver side? Or was it a sudden change and doesn't blow "coolish" at all?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    Unless the thieves decided to put the jack under the compressor or the condenser (and damaged one of those), I think it unlikely that the 2 are related.
    I would "forget" that the cat was stolen and just diagnose the A/C by itself.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Nope it’s just age.
    You have a leak it’s probably not been very cold for awhile. Very bad for compressor not fully charged. Compressor is crazy expensive.
    It may be leak in evap coil under the dash. Very common. Pre Covid mine failed $1100.
    Take it to Car AC shop. They’ll charge it up with dye and find the leak.
    Don’t take it to the dealer.
    To any lurkers the PRIUS G2 has a fantastic AC system it should be really cold on high. If not you have a very slow leak and that should be addressed
    Before it kills the compressor.
