Catalytic converter theft design by Toyota?
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Feb 3, 2022.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    941
    Sparks, NV
    This screenshot is from a recent video of the 2022 regular Prius. Can any 2022 Prius Prime owners confirm that they have this? By design or not, helps prevent catalytic converter theft. Screenshot_20220203-144354_Facebook.jpeg
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    You van go to the Toyota dealer and order one. Instead of the standard fasteners, you cam use security Torx screws.
  3. Marine Ray
    1,139
    941
    Sparks, NV
    Looks like this OEM piece does nothing to deter the thieves. Pic shows where the cross member was cut to access the front of the catalytic converter. Screenshot_20220203-150634_Facebook.jpeg
  4. Marine Ray
    1,139
    941
    Sparks, NV
    90069WH, Northerner and don_chuwish like this.
  5. Marine Ray
    1,139
    941
    Sparks, NV
  6. MikeDee
    MikeDee Senior Member
    1,549
    590
    San Francisco Bay Area
    I put catalytic converter shields on both my Priuses. Almost sorry I did because they are a source of noise. I think the convertor may be rubbing under high power.
  7. pghyndman
    pghyndman Active Member
    498
    465
    CT shoreline
    We installed a Miller Stainless Steel cat shield 9 months ago and have had no issues. The kit included Torx style anti-theft security bolts and bit as well as spacers to alleviate scraping the frame.
  8. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Yes the 2022 Prius Prime has the crossmembers and the cat is stuffed closer to the engine. Although harder to access, I decided to still add the Miller shield to my 2022 PP and I have no rattle noise by following the instructions.
    Because it is a pain to install, it seems like some are not installing the shields properly and it results in rattles.
    Here are a few insights: Miller Cat Shield Gen4 | PriusChat
    iPhone ?
    #8 eow, Feb 5, 2022
    pghyndman and Marine Ray like this.
  9. Mendel Leisk
    38,644
    I think you've gotta take that guy with a grain of salt. He is pretty deep into the Toyota "culture". There's a stiffener plate, with a few regular bolts, which happens to be near the cut point? It'll help, but I doubt that's it's intent.
  10. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    That probably adds about 20 seconds to the time needed. The saw will go through that aluminum like butter.
  11. MikeDee
    1,549
    590
    Probably easier to cut those much thinner cat shields too. Hopefully, it makes it more than enough trouble and the thieves move on to easier pickings.
  12. Trollbait
    11,504
    Depends on what the metal is.
  13. MikeDee
    1,549
    590
    Usually aluminum. One I saw was stainless steel.
  14. Jayne K
    Jayne K Member
    50
    27
    Utah
    I just checked with my Toyota dealership. There are no shields fire the Prime!!!
  15. MBurch
    MBurch Junior Member
    29
    28
    Snohomish, WA
    2022 Prius Prime
    maybe not at your Toyota dealership, Millercat has the right one for a prime - fits perfect and rather easy to install (I thought)
    MILLERCAT 2016-2022 Prius Gen 4 Cat Shield™
    Merkey and pghyndman like this.
  16. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    pghyndman and Pdog808 like this.
  17. BiomedO1
    BiomedO1 Senior Member
    1,440
    787
    SacTown, Ca
    Yep, Someone cut one out of our gen4 Prius at work, when it was at the depot for maintenance. We got security cameras in all our parking garages; but for some reason - none at our fenced in repair depot parking lot. Go figure????(n):whistle::censored:
  18. Pdog808
    Pdog808 Active Member
    413
    271
    Los Angeles
    2018 Prius Prime
    I have the stainless Miller Cat shield on my 2018 Prius. No rattles or noticeable noises in either EV or HV at slow or high speeds.
    Then again, I had it installed by a local Miller Cat authorized installer.
  19. jerrymildred
    11,508
    14,109
    Tampa, FL
    I don't know about other generations, but when we install a cat shield on a Gen 2, we replace the rubber exhaust hangers behind the cat with shorter ones so it won't rattle on the shield.
  20. Washingtonian
    Washingtonian Senior Member
    715
    616
    Wouldn't your theft insurance for your car cover theft of a catalytic converter? I am assuming that since I park my car in a locked garage every night that the chances of cat theft are pretty minimal for me.
