Catalytic Converter Theft?
Discussion in 'Gen 3 Prius Main Forum' started by Captain Caseous, Apr 24, 2022.
  1. Captain Caseous
    Captain Caseous Junior Member
    Like other places, catalytic converter theft has taken off in my area. Before I installed cameras, set up man-traps, and post sentries, I'm wondering how vulnerable a 2012 Gen 3 with 100K+ miles is? Are mostly new Priuses (and thereby, newer catalytic converters) the target for resale or is it just the platinum, rhodium, and palladium, which would mean any Priuses are vulnerable? What do you think?
    49,511
    very vulnerable. the age doesn't matter. gen 2 have the most precious metals, gen 3 next and then gen 4.
    order yourself a trunk monkey ;)
  3. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    For starters a prosecutor and judge will only look at the fact that you deliberately intended to seriously injure someone with your man trap and the fact that you were defending your property from theft will not be considered in your sentencing.
    That being said, they overbuilt Gen2 Prius cats to be as clean burning as possible so you have roughly a couple grams each of Rhodium, Palladium and Platinum. Currently the value per gram is: Rhodium ($598), Palladium ($78) and Platinum ($31).
    johnHRP likes this.
  4. johnHRP
    johnHRP Active Member
    417
    133
    tally, fl
    We should add any kind of protection. I use simple D shape catalytic converter and it works fine.
    I put secure bolt on the rear side where there are 4x3.2mm washers/spacer to avoid exhaust rubbing. The secure bolt is the same as secure bolts for VW wheels. M12x1.25 pitch.
  5. Mendel Leisk
    38,739
    We noticed this book at Lee Valley Tools, recipes from the late 1800's through early 1900's: Lee's Priceless Recipes. One page caught my eye:
    (Apologies to the long-sighted, you will need a magnifying glass for this)
