Catalytic Converter: Which should I go with?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dat Boi, Nov 30, 2016.
  1. Dat Boi
    Dat Boi Junior Member
    36
    Alton, Illinois
    Hi everyone!
    I just hit 301K, and my MPGs are dropping, along with the CEL staying on more than usual lol. (P0420)
    The cat is failing, so it's a good time to replace :)
    Every muffler shop in the area refuses to use anything that isn't bolt-on, so I said to heck with them and will be doing the job myself with a bolt-on assembly. The guys could barely figure out how the shifter worked to get it on the lift...
    And I won't be taking it to the dealer, lol.
    I've looked at a few options, which should I go with?
    Option 1:
    BRAND NEW CATALYTIC CONVERTER FOR TOYOTA PRIUS GENUINE MAGNAFLOW DIRECT FIT | eBay
    Option 2:
    Option 3:
    Best Designs Direct Fit Catalytic Converter Fits 2004-2009 Toyota Prius 1.5L | eBay
    The shop also said that option two would be the better option, since it's closet to OE quality. Option 3 is the least expensive, but are they that bad? Option 1 would be the middle ground.
    Any input would be appreciated!
  2. JC91006
    16,673
    8,518
    You can buy a magnaflow on Amazon and just weld it on. $75
    Magnaflow 99205HM Universal Catalytic Converter
    Aaron Vitolins likes this.
  3. Dat Boi
    36
    Alton, Illinois
    If I had the equipment, I would!
    Every local shop keeps telling me that they can't weld it on and will only install the bolt-on assembly .
    I ended up going with the direct fit so I can do the job without having to weld anything
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    How long do you intend to keep the car? If more than 6 months, either get an OEM cat or a pair of spark plug anti-foulers, drill a 1/2" hole in one then install them in the exhaust pipe before re-installing the REAR O2 sensor.
    Toyota (and Subaru) are NOTORIOUS for setting P0420 DTCs (low cat efficiency) when it is performing WELL within emissions standards, but yes, slightly degraded. What I am telling you is THE CAT IS NOT BAD.
    JohnInArizona likes this.
  5. pri2004
    pri2004 New Member
    california
    I am wondering - did you get the 'best designs' or did you go with magnaflow ? they all claim to be 'direct fit.'
    smog passed ok after you were done ?
    Is there anyway i can do this bolt deal myself - or have to go to a shop with a lift, etc. ?
    thx
  6. JC91006
    16,673
    8,518
    You can get a bolt on version from eBay for about $260
