Catalytic Converter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Olscratch, Sep 21, 2018.
  1. Olscratch
    Olscratch Junior Member
    My gen 3 2010 prius has been throwing a po420 for a while and I want to change out the catalytic converter.
    Is it just bolted on or welded on? Where is it located on the prius?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    It should be bolted on, it shouldn’t be welded on. It’s underneath your vehicle, it’s after the exhaust manifold.
    Olscratch and Robert Holt like this.
  3. Mendel Leisk
    38,704
    I've attached an excerpt from Repair Manual. There's an odd duplication, maybe the versions with/without exhaust heat recirculation, I haven't really read through it. The manual is very terse, but has info.
  4. ETC(SS)
    6,552
    The really good news is that since you live on somewhat freer soil, you can buy a new bolt-on replacement for less than $200 - shipped, and you may be able to yank one off of a salvaged car for less.
    Good Luck!
  5. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Could I just add that it kind of looks like a smallish muffler, but if you are under there and carefully look down the length of the exhaust system, you will see the real muffler a bit “downstream “ from the catalytic converter.
    Thank you ETC(SS) for the price quote, as the doggone things used to be very expensive and I am relieved to know that getting one for our 2012 won’t be such a hard knock, if it becomes necessary.
    Olscratch and ETC(SS) like this.
  6. Mendel Leisk
    38,704
    Am I reading this right, the kosher part is $1200 and change?
    Exhaust Components for 2010 Toyota Prius | Toyota Parts
    So if you go aftermarket you cut off and weld in a just the catalytic converter portion?
    Here's some info on the Oxygen Sensors, I think they need to be transferred over?
    Olscratch likes this.
  7. Olscratch
    Thanks for the replys folks. I seem to have located the cat, taking off some heat shielding I noticed this reservoir looking quite melted, very thin where the color is dark.
    Anyone know what this thing is?
    I got this 300$ cat off rockauto
    Looking down at the bolts on the old cat
    The other end appears to be welded, I cant really tell maybe its only rusted.
    Robert Holt likes this.
  8. Robert Holt
    1,313
    888
    Not sure, but the thing sticking out to the left in picture number 3 that looks kind of like a super-sized sparkplug is the oxygen sensor, i believe. Usually they are really rusted in, so be careful when you try to back it out and expect it to be a PITA.
    Not sure what that melted plastic thing in pic 1 is, but it surely would be good to know if it is successfully functioning or not, especially after you install the new cat.
    Good luck and thanks for pics!
  9. ChapmanF
    15,562
    I'm not sure what you were referring to in your first picture, but in the center of the picture is nothing but a white plastic shield that covers the orange high-voltage cabling from the battery to the engine compartment, to protect it where it makes a bend or passes through the sheet metal.
    The OEM exhaust was made in only two parts: the forward part attaches to the manifold in front, includes the catalytic converter(s?) and the heat recycler and a long squiggly pipe all the way back to the one bolted joint to the aft section, which is a shorter squiggly pipe, the muffler, and tailpipe.
    The part you bought looks like they probably expect you to cut your original front pipe assembly ahead of the heat recycler and weld your replacement part to it.
  10. Olscratch
    Well looks like I'll be taking it to a shop to have the cat welded on.
    If I understand you correctly chapmanf, you're saying it doesn't really matter if this plastic is melted through because it is only protection for the high voltage cable.
  11. Mendel Leisk
    38,704
    I was looking into Oxygen sensor replacement for a while, have these two items in my Amazon "save for later":
    You should research to verify they're compatible, I'm not sure myself, but those were two options I was considering. Can you get a caliper on on either, check the face-to-face dim of the hexagon faces?
    You could search for the sst number in the attachment, in my post #6, maybe that's what I did as well? Can't recall.
  12. ChapmanF
    15,562
    I don't think it's going to hurt anything. It might not be hard to find a way to heat-shield it a little better as you're putting your exhaust back on, maybe cut a little piece of aluminum sheet to roll loosely around it. (Would probably want to fold/beat the edges smooth to make sure you're not making anything that could dig into the cable, which would be protecting from one problem by making a worse one.)
    -Chap
  13. Olscratch
    Update: Just had the new catalytic converter put on. They said it was easy and had it welded on in under an hour.
    They cleared the po420 code so it's no longer showing a check engine light but for some reason the red Brake light now is stuck on, along with the ABS light, and the traction symbol. Seems to be driving fine, but they were at a loss with what could have caused those lights to come on. Also driving it back from the shop I noticed the cruise control symbol flick on and off. Anybody have any idea what the hell is going on with it before I haul it up to the dreaded toyota dealership?
  14. Mendel Leisk
    38,704
    If they can clear codes they must be able to read codes, and if there's a lot of warning lights there must be code(s).
  15. Olscratch
    I went back and had them read it and they said there are no codes. Took it by NAPA on my way back to the office and they also said its showing no codes.
  16. Mendel Leisk
    38,704
    Maybe a visit to dealership ($75~) and a Techstream check is needed. I've had similar lights (brake, ABS, etc), plus "CHECK HYBRID SYSTEM")when it was apparently my ScanGuage being constantly hooked up to the OBD port. I brought it into the dealership I believe 3 times, and the last time the mechanic noted that when he wiggled his OBD port connector he was intermittently loosing signal. He suggested I try disconnecting the SG, and see if that stopped the warnings.
    That was over 3 years back, I took his advise, and no further warnings lights. Bottom line, it might just be some sort of intermittent drop-of-signal, caused by the shop hooking up, jiggled something. Try the dealership, I'll bet they will find codes, and maybe if they dismiss them they'll stay gone? Knock on wood.
    #16 Mendel Leisk, Sep 27, 2018
  17. Olscratch
    Thank you. I plan to go home and disconnect the 12v for a bit and see if the warning lights persist. If they do I'm going to take it to the dealership to have them Techstream check it.
  18. Olscratch
    Disconnecting the 12v did not help and the 3 lights persisted. Checked all the fuses related to ABS, all were fine.
    In addition to the 3 warning lights I also have noticed the power windows all stopped working except driver window. The cruise control has also stopped working. And lastly the regenerative braking seems disabled.
  19. Mendel Leisk
    38,704
    Somehow the muffler shop did a real number on it...
  20. NutzAboutBolts
    1,476
    1,552
    Bay Area
    I wonder if they messed with any of the abs components. I know if the abs control module a.k.a ebcm is faulty, the parking and abs light is lit, also the traction control is part of the abs circuit. I would look through that area.
    Mendel Leisk and Olscratch like this.
