Catalytic converter
Discussion in 'Gen 2 Prius Main Forum' started by Mel Crittenden, Mar 3, 2025.
  1. Mel Crittenden
    Mel Crittenden New Member
    Yuma AZ
    Hi there, my converter was stolen and I had a replacement after market installed that I purchased from Amazon. The reviews were good and it did well for about a year and now I’m getting an engine code for it. Mechanic said that the valves can be damaged if the engine code is triggered due to the fuel ratio being too rich. I’m not a mechanic and not sure if this is accurate, anybody have any experience? Will the car be damaged if I continue to drive with the engine light on?
    I’m sure this has been discussed but I can’t seem to find things in the forum. Thanks in advance.
  2. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    In order to reason objectively, the detected error code is necessary.
    A constantly lit check engine light is dangerous because you get used to it and can miss a serious problem.
  3. Mel Crittenden
    Yuma AZ
    The error code is for the catalytic converter. Cost total of $900 to replace.
  4. BiomedO1
    BiomedO1 Senior Member
    4,114
    2,157
    SacTown, Ca
    You can't damage the valves, if the car is running rich. You can fry the CAT if it's running rich or you have excessive oil burn. We can't see, smell, or hear the car over the internet, that's why we're asking for error codes.
    There's a communications issue here. Either you misunderstood what the mechanic told you or the mechanic is full of CRAP. As I explained above. There's several ways to kill a new CAT or that CAT was defective. That's why we ask for the error codes. A good, professional repair shop would've checked for those other issues, before installing a new CAT; because they need to warranty their work. If a customer drags in their own part and tells them to just replace this. That's all they're going to do. The only warranty your going to get is that it won't fall out of the car.
    @MAX2 stated; if another fatal issue crops up; you won't know, until the car just stops running - since your CEL is already lit.
    #4 BiomedO1, Mar 3, 2025
  5. Mel Crittenden
    Yuma AZ
    The mechanic did check the codes and said it was the catalytic converter functioning below efficiency, I think he said a P code, he said it could make the car stop and maybe I misunderstood that he said damage the valves. The one I bought off Amazon was an inexpensive one so maybe that’s why it only lasted a year. I don’t want to damage anything by ignoring it , I want to get a few more years out of the car if I can.
  6. BiomedO1
    4,114
    2,157
    SacTown, Ca
    Those P-codes are what we need to do a remote diagnostic. Anyone can say what they think the problem is (ie. low cat efficiency - P0420); but that's their interpretation of that code. Was there any other codes the car kicked out? A lot of us with experience fixing cars, can tell you the most likely part failures, when you give us a bunch of error codes the ECU kicked out. But when you tell us your mechanic thinks is this - what do you want us to say?
    Price has nothing to do with it. Both Amazon and E-bay are flooded with counterfeited parts. If your car is running correctly, it shouldn't have destroyed the CAT. Figure out what the warranty is on that part, normally 2 years or 24K miles - but you'll need to prove that it was installed correctly and the car was also running correctly. If you had a repair shop sell you the entire job, they would be on the hook for the warranty repair.
    Catalytic Converter Warranty: Owners' Peace of Mind
    Good Luck.....
    #6 BiomedO1, Mar 3, 2025
    MAX2 likes this.
  7. rogerthat
    rogerthat Active Member
    408
    125
    Georgia
    I replaced mine about 4 years ago with a similar aftermarket cat. It lasted about 13 months before the P0420 code. I then installed a spacer on the same aftermarket cat and went another 2 years until I recently got some other codes (P0606 and P0137). Based on some research/guessing, I replaced the cat with another aftermarket cat and also switched out the downstream O2 sensor. It's been about 300 miles and the codes have yet to return. I'll be happy if this cat gets me through the next two emissions test.
  8. BiomedO1
    4,114
    2,157
    SacTown, Ca
    Congrats on passing smog for an additional two years; but if that smog station saw that spacer - that would've been an automatic failure. That wasn't a fix, you simply took the sensor out of the exhaust gas flow stream. (ie. fooled the ECU, but it eventually figured it out.)
    YMMV
  9. rogerthat
    408
    125
    Georgia
    Yes, I'm well aware of what the spacer does. Of course, after replacing the cat, I no longer have the sensor attached but I'll do it again when this latest cat fails... worth the risk for me. I've never dropped under 46 mpg and the car runs well.
  10. Frontporch
    Frontporch Active Member
    535
    121
    Nj
    I always thought when comparing a $150 replacement to the $1700 original, that it was surprising that the aftermarket worked at all. I think 1 year of trouble free service is reasonable to expect for these cheaper parts.
    In my mind it was enough to get me through emissions for another two years and if i had to replace it again in two years, so be it. Of course i am not paying labor for these.
    The aftermarket must provide just enough to rare metals to make it work... whatever chemical reaction happens, it will slowly reduce its effectiveness over time... The OEM part was well equipped to handle the conditions but the aftermarket... should be no surprise it has such a short life.
    I always believed that code said it was not meeting the expected efficiency, not that it wasn't working at all. Just old and tired. This may have some change to the way the engine runs, but I don't know that I would be that concerned.
    I hate the check engine lights being on, but if you have a bluetooth OBDii reader and an app on your phone you can periodically check that there are no other codes for peace of mind.
    The last prius I had with an aftermarket cat got great mileage... a trip from NJ to Ohio had me up around 49 MPG. I wonder if that aftermarket cat might have helped with lower back pressure or something... who knows. After that car I had one with the OEM unit and i was lucky to see 45 MPG. It did have 275K miles and burned some oil... also a big factor.
  11. Thomas Zak
    Thomas Zak Junior Member
    Los Angeles
    Are we allowed to posts parts for sale on this chat group? I have a like new OEM cat that was pulled from a 2008 prius that did NOT burn oil. It had been recently replaced because of theft. I'm located in Southern California.
    Sophie2007prius likes this.
  12. Thomas Zak
    Los Angeles
    Pic
  13. Thomas Zak
    Los Angeles
    626.679.2791
  14. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
