Catalytic Converter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MelissaAnne, Jan 29, 2011.
  1. MelissaAnne
    MelissaAnne New Member
    265
    52
    Louisiana
    Back in June of last year I bought a used 2006 Prius from our certified Toyota dealership. It had a lot of miles on it (230,000) but they reassured me that a Prius would last well past 400k if taken care of properly. They gave me the paperwork on all the service it had from the only owner of it and showed they took well care of it.
    So I buy the car and within a week of paying them $4,500 down, my check engine light went on. I brought it in and they said they need to do a diagnostic test (which of course is 120 dollars). So I do that and they say the cat converter is only holding oxygen for 1-2 seconds and should hold a lot longer. So then they said I needed to get a brand new one at $1,800 (I lived in California at the time).
    They restarted the check engine light so it wasn't on anymore. Now it randomly comes on and stays on for up to two weeks and then randomly goes off again. My Prius is getting 41mpg. I also was able to drive it from CA to LA in three days which was 2,300 miles.
    So, I assume I should get it replaced? I heard they could clean them out for you if the only problem is it being clogged, they just couldn't in CA. Also, upon getting it replaces (or cleaned out) should I replace any other parts as well?
    My mother has a 2007 Prius and hers accelerates a lot quicker than mine and when I step on the gas it sounds like my car is trying its hardest to gain speed, like an electronic buzzing noise. Any suggestions on that too??
    Thank you for reading my post and I'm sorry it's so long. I just wanted a Prius ever since my mom bought hers in 2007 and I finally got my own and was so disappointed.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Certainly if your exhaust system is clogged, the car would make less power and get worse mileage.
    I do not believe you can legally install a used catalytic converter in a car in the US but new units on ebay are under $300 (I am sure they are more locally)
    Walker Direct Fit Catalytic Converter 16337 - eBay (item 330522254207 end time Feb-21-11 03:52:42 PST)
    Any nearby garage would be able to install it for you, even if, as is likely, they do not stock them. (Walker is a good name in exhausts) http://www.walkerexhaust.com/catalog/ExhaustCouponScreen_49_State.asp?Coupon_ID1=16337
    If you prefer DIY , I would buy a new gasket and 3 bolts/nuts at the dealer, and be prepared for a lot of rust.
    After the converter is replaced, you may still need to go back to a Toyota dealer to clear the codes so the check engine light goes off.
    Another one from a company I have never heard of 04 05 06 07 Toyota Prius 1.5L Main Catalytic Converter - eBay (item 190341378730 end time Feb-04-11 08:33:10 PST)
  3. Patrick Wong
    18,200
    6,474
    It would be best for you to replace the catalytic converter, if you don't wish to pollute the air unnecessarily. I suggest that you visit your local muffler shops to see what they can do for you regarding installation of an aftermarket unit. The original equipment catalytic converter probably is clogged with rust, which impairs engine performance.
    I recommend that you perform the equivalent of the 100K and 120K mile services (which includes engine and inverter coolant replacement, iridium spark plug replacement, engine and cabin air filter replacement, and inspection of the chassis and brakes) unless you know for sure that the car was recently serviced to that full extent.
    Regarding clearing the existing DTC codes, that can be easily done by disconnecting the 12V battery negative terminal for a few minutes. You may want to figure out how to do that to save yourself $100 at the dealer.
  4. MelissaAnne
    265
    52
    Louisiana
    Okay so I might as well get it replaced. I'm kind of skeptical about local garages. I moved to Louisiana and haven't seen many Prius' roaming around these parts. Mostly big trucks here. I figured there was more to changing the catalytic converter in a Prius as opposed to a regular car. My boyfriend said if I bought one he would cut the old one off and put the new one on but I'm a little hesitant. My Prius is now my baby.
    As you said Jimbo, I should look into Walker. I found this one:
    (guess I can't post the link because I'm new)
    It's from theautopartshop website. after ".com/" add in "Search/PartDetails.aspx?gPartNum=07ToyPrius/WK16337&proid=toyota+prius+Catalytic-Converter+Walker+165714&Pat=auto+car-usa+Parts+Brand+PartDetails
    If that is good it is much better than spending the dealerships price.
    At the moment my check engine light has been off for about a week and a half. I noticed it would go on when I put gasoline in it other than Chevron.
    Wow, this is extremely helpful. Thank you so much for the replies. I really appreciate it. I love my Prius. Hopefully when I get the cat converter fixed it'll accelerate quicker so my boyfriend can stop making fun of me for owning a Prius.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Yes, LA is the second least likely place to see a Prius in the US after MS.
    Since you are new to LA, here is a site that recommends local mechanics, although your boy friend should be able to repair this with adult supervision. (you)
    Car Talk | Mechanics Files
  6. Patrick Wong
    18,200
    6,474
    No, the Prius catalytic converter is the same in concept as any other car. If your BF has access to welding equipment and prior experience working on auto exhaust systems then you should be good to go.
    Given your car's odometer reading, maybe your BF should start by replacing the air/fuel ratio sensor which is located upstream from the catalytic converter. If he is game, I recommend that you use the correct Toyota part instead of aftermarket. This is a much easier task than replacing the catalytic converter.
    Then, if after the A/F ratio sensor is replaced, you still notice that your engine lacks performance, you can ask your BF to replace the catalytic converter.
    Data Daedalus likes this.
  7. rpeeples
    rpeeples Experienced Toyota Owner
    109
    America's own third-world country
    Not that I am suggesting you do this, since it might cause the check engine light to stay on permanently, or maybe all kinds of other weird stuff. I have heard of people removing the CC altogether buy cutting it out and replacing the gap with a pipe, or removing the innards of the CC and only keeping the shell. Again, I have no idea how all the computerized gizmos will react to a missing part....
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    autobeyours.com. A shop will NOT install a used cat. But your boyfriend on the other hand, ...
  9. MelissaAnne
    265
    52
    Louisiana
    Well even if I end up allowing my boyfriend to do it, I'm still going to buy a new one. That's still only about $300 and making him and sandwich or two. That's still a lot cheaper than the dealership.
    A few people told me to just remove it completely but those people also owned 1970 mustangs that didn't pass smog. Also, taking the cc off may make it sound louder, plus isn't the cat converter helping the release of emissions?
    My boyfriend is telling me the local places will do it for cheaper but than I'll have to worry about whether or not they cleaned it out well enough. Then continually going back until I get fed up and give up.
    I've decided I'm just going to buy a new one. On top of that I suppose I will also replace other things like the air/fuel ratio sensor. My boyfriend is a pipe fitter so he also has welding tools available.
    So, other than the cat and the sensor, what else should I replace? This is still a lot cheaper than when I lived in California.
  10. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    As I recall, there are oxygen sensors just before and just after the catalytic converter. When they read the same value, then it's obvious that the catalytic converter isn't doing its job. The exit one should indicate that the exhaust is cleaner after passing through the converter.
    I don't know how to sort out which components are causing the check engine light. But it seems possible that it could be the oxygen sensors and not the converter. On the other hand, we just replaced the converter on a BMW with 200,000+ miles and the hydrocarbon pollution when down by 90%.
  11. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Removing the cat completely will only make her problem worse. The check engine light will be on constantly because the emissions system will sense that the exhaust gasses are not being treated. That, and anyone behind her will have to put up with the stink of untreated exhaust.
  12. Patrick Wong
    18,200
    6,474
    I assume that you are going to ask your BF to do this work:
    1. Replace the iridium spark plugs with the correct NGK or Denso plugs as specified in the owners manual.
    2. Check the engine and cabin air filters and replace if dirty.
    3. Replace the engine and inverter coolant (see my posts on how to do both.)
    4. Inspect the brake and suspension systems. Very likely that the front struts and rear shocks need to be replaced. I've also posted on how to replace those. If it is necessary to replace the brake pads or shoes, disconnect the 12V battery before beginning work to avoid inducing DTC into the skid control ECU.
    techinfo.toyota.com is the official source of Toyota repair manual info.
    This is why I suggested replacing the air/fuel ratio sensor, which is located in the same spot as the first oxygen sensor would be in another vehicle (but has a fancier name and works slightly differently.)
  13. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    Hate to be the one to rain on the parade here but I figured I would chime in before you waste money on an aftermarket cat. Aftermarket cats unfortunately don't seem to work on Toyota vehicles. I don't know if the programming of the car is just so sensitive or if the aftermarket cats just aren't good enough. Any car we've ever had a P0420 or P0430 and a customer has put on an aftermarket cat the vehicle has always returned the same DTC's after the Catalyst Monitor completes its check (this is of course after the original DTC's have been cleared). The catalyst monitor doesn't operate all the time. RPM, MPH, and throttle angle all have to stay in a certain range for X number of time for the monitor to run. So if you put an aftermarket cat on and clear the codes and they don't immediately come back on don't think your'e in the clear just yet. Just wanted to my $0.02 in from what I've seen.
    douglasjre likes this.
  14. Patrick Wong
    18,200
    6,474
    Hi Josh,
    Do you think that it would help if Melissa narrowed her selection criteria to choose from aftermarket catalytic converters certified for sale in California?
  15. MelissaAnne
    265
    52
    Louisiana
    Do you know how I would go about checking the oxygen sensor readings? Is there a specific value on each that determines if maybe they need to be replaced as well?
  16. MelissaAnne
    265
    52
    Louisiana
    Yes, I believe I'm about to allow my boyfriend to touch my car. It's enough that I allow him to drive it. My brakes actually squeak a lot when I'm backing up, I've been wanting to check those for a while.
    Alright well, this looks like some stuff I can afford to replace. Now, if I can only do one thing at a time (seeing as how my bf works 12 hours a day, 7 days a week) what is the best thing to start first in your opinion? I don't want to replace one thing and find out that I should have replaced something prior to that.
  17. MelissaAnne
    265
    52
    Louisiana
    Well, I would've paid about $0.08 for this reply. So, all this being said, is there any way I can buy an OEM catalytic converter specifically for my car??
    Every time I search for one made for my car I keep getting this one:
    Eastern Catalytic 40712 at AutoAnything
  18. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Does such an aftermarket product for the Prius even exist?
    This is one of the unintended consequences of the Clean Air act, where a salvage cat from a low mileage car performs better with a longer expected lifespan than a brand new aftermarket replacement, but is technically illegal.
  19. MelissaAnne
    265
    52
    Louisiana
    I remember when I first was told I needed a cat converter and getting a used one was impossible. Once a Prius gets in a wreck that is something they remove before putting it in a salvage lot.
    I was planning on a staged car accident in front of the dealership that would've happened to involve a truck and a prius. I told the mechanic to be ready to grab the cat converter before the police arrived. It never happened. :(
  20. Patrick Wong
    18,200
    6,474
    You could use an oscilloscope to look at the voltage waveform produced by the air/fuel ratio sensor upstream from the catalytic converter, and compare to the voltage waveform produced by the oxygen sensor which is downstream from the catalytic converter. You expect the former waveform to show rapid changes in voltage while the latter waveform would show relatively constant voltage.
    The engine ECU does this comparison automatically, as these are some of the parameters that ECU is responsible for tracking.
    Since you did not say that you have any DTC that show either part is bad, then you don't have to worry too much about this.
    I recommend that you focus on getting the engine's responsiveness back to where it should be. If you agree, then I suggest that you start with replacing the iridium spark plugs and the air/fuel ratio sensor. Although the engine ECU did not identify the A/F ratio sensor as a failed part, over time the sensor loses its ability to track changes in the A/F ratio and the voltage changes become sluggish. This would impair engine performance and also might be part of the reason why the catalytic converter error code came up.
    Also, check the engine air filter and replace that if it is dirty. Remove the air filter from the housing and hold up to the sun. If you don't see much light coming through, replace the filter. Compare to a new filter if necessary. When reinstalling the filter, note that the dirty side is face down and the rubber tab on the gasket fits into a corresponding space at the rear of the air cleaner housing.
    Additional items: Clean the mass air flow sensor and the throttle body interior and throttle plate. Remove the MAF sensor from the air cleaner housing, then spray the two wires and the amber bulb with MAF sensor cleaner. Remove the air cleaner housing from the throttle body, apply throttle body cleaner to a clean cloth or paper towel, then scrub off the black gunk on the throttle body interior and throttle plate. You can rotate the spring-loaded shaft of the throttle plate in order to clean its edges and the underside.
    Then, clear the existing DTC by disconnecting the 12V battery negative cable for 5 minutes. See how well the powertrain operates. If the engine performs well, then you don't have to worry about replacing the catalytic converter unless DTC P0420 comes back.
    Yes, that Eastern catalytic converter looks good. Too bad Josh reported that it may not work as well as you might expect.
    You can buy the correct catalytic converter for $1,186 plus shipping here:
    Champion ToyotaWorld
    However I recommend that you defer this purchase until you see what happens with the other engine work described above.
    Excellent point. In the distant past I bought a replacement catalytic converter for my 1988 BMW 325i convertible, while living in Silicon Valley. However I just did a quick search and could not find any Prius catalytic converters for sale to CA residents, other than the correct Toyota part.
