Catastrophic brake failure Gen3 Prius
Discussion in 'Gen 3 Prius Main Forum' started by Jerry Harris, Oct 10, 2018.
  1. Jerry Harris
    Jerry Harris Junior Member
    London
    I purchased a 2010 Gen3 Prius a few months ago & there was a misfire in cylinder 1. I did not have a spark plug remover to remove the cylinder 1 plug & check. So I took it to Vantage Toyota at Preston, Lancashire, United Kingdom. I was initially booked for half of hour for an investigation. While I was there, I was told that they need a further half hour & then another 1 hour to do this complicated inspection. My car is fitted with CCTV & I could see the mechanics going all over in circles trying to identify a cylinder misfire. I was even told that there might be a head gasket problem. After all that time, Vantage billed me for 2 hours labour to clean & refit the same old spark plug which was day light robbery. After this bad incident I did not want to step any Toyota dealership ever.
    Now my Prius is having catastrophic brake failure. I called today (10/10/2018 @ 16.30hrs) & spoke to a lady quoting my registration number. I explained my issue & was told to contact Toyota recall administration to check if there was a recall for my particular issue. As I expected I was told that there is nothing wrong with my model & all should be in ship shape. From past, I have learnt about fatal accidents involving the same brake issue in the USA.
    Please check CNN news URL below:
    Please forward to 2 minutes & 30 seconds on the video & this is the exact same problem I am having with my car. Maybe there is no recall for my car, but there is certainly loads more people experiencing the exact same problem as I am having.
    When driving slowly over an uneven or a slippery surface & you hit a grit or a pot hole, I step on the brakes & the brakes do not respond immediately for a moment as if there is no traction & the car just slips. The brakes response is fine if moving at high speed or if stopping at an emergency. But it loses total braking capability if the car hits a pot hole or a bump when braking.
    When I called Toyota customer relations, they asked me to call my local Toyota dealer & book the car in for an inspection. With my previous experience of booking for a simple inspection which would have lasted 15 minutes, but somehow took 2 hours I am reluctant to take it to you as I will be billed for an insane amount as I have lost all faith in your dealership.
    Does anyone have similar experience or would like to add as to what might be wrong with my car.
    Kind regards
    52,401
    this is very common with the prius. when you feel the brakes 'slip', press harder. it usually happens at low speeds when transitioning from regen braking to friction, in combination with traction control.
    besides the recall, there may be a software update available to you. plug your vin into the toyota owners website if that is offered in the u/k.
    Jerry Harris likes this.
  3. ChapmanF
    18,566
    You're not describing catastrophic brake failure, you're describing what every Prius does if it gets triggered to switch from regen to antilock braking in the middle of a moderate use of the brakes.
    Not really; it drops the regen immediately to make sure it can't lose steering traction, and brings in the four-wheel ABS within a split second. Because any urgent braking (detected by the pedal angle sensor rate of change) goes straight to ABS from the start, this is a behavior you can only experience in moderate braking situations, and I've never had the split-second that it takes ever bring me anywhere near hitting anything.
    When I first bought my Gen 1 ten years ago, posters right here on PriusChat advised me to just go out on some gritty, potholey road and do moderate braking until I was used to how it felt. That's still the best advice going.
    Now, if you've got a 2010, it would not hurt to just check that the A0B recall was done on it. That was a software update. It didn't eliminate the regen-to-ABS transition (something every Prius model has always had), but there was apparently something about the early 2010 software that made it feel scarier to more people, and the A0B update toned that down somehow. (Maybe it changed more than that; we the unwashed don't get to read the source code.)
    You can either look up your VIN on the Toyota Owners site and see that the recall was performed, or look for a sticker about it, or use Techstream and get the software version from the brake computer. If it is F152647106 or later (if you have 15 inch wheels) or F152647126 or later (17 inch wheels), the recall was done (or the car was built late enough not to need it).
    Edit: I just noticed your location ... I do not know whether the USA recall identifier, or the USA left-hand-drive software version numbers will be right for you, but the general information holds.
    -Chap
    Sporin and FuelMiser like this.
  4. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    After reading, this is not a catastrophic failure. It’s normal for Prius brakes to slip on potholes, bumps etc.
    The fix is to buy another non Prius vehicle, like Honda Civic hybrid.
    Sporin likes this.
  5. JackTheNarrator
    50
    Los Angeles
  6. Mendel Leisk
    41,924
    @Jerry Harris how many miles on it? And how was it initially deemed that there was a misfire in cylinder #1?
    FYI, getting to the spark plugs is a royal pain: the wipers, their motor and linkage, bottom of windshield trim and a large metal cowl, all have to be removed. Lots of cables need disconnection, and there's maybe 30 bolts to remove. Just to get to the spark plugs, lol.
  7. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Glad others have clarified this issue. We all get it, that split second of "!!!" when, under just the right conditions, you feel that swap from regen to friction brakes. This only happens on a slick surface to me, so I assume TC is involved somehow in exaggerating this transition, which you otherwise don't feel much.
    I have a regular turn I take in my town that triggers this frequently, there's a manhole cover right in the braking zone and if it's wet and I hit it just right, I cna "make" that "!!!" feeling happen.
    I agree, it's disconcerting when you don't expect it, or know what it is.
    Jerry Harris and Grit like this.
  8. bisco
    52,401
    IT'S NOT DISCONCERTING, IT'S CATASTOPHIC!:eek:
  9. bisco
    52,401
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    He needs another story;).
  11. ChapmanF
    18,566
    It's not just slick surfaces ... there's a pothole on the way out of my neighborhood that'll do it every day without fail, wet or dry. It isn't traction control, it's just the brake ECU switching from regen braking (all done with the two front wheels) to ABS (done with all four) for better control. It is triggered by the ECU thinking you might be losing traction, but you don't have to be really losing traction. Taking one wheel over a bump or pothole momentarily gives the ECU different speed signals from the wheels, just because one wheel is legit rolling a different distance than the other. But the ECU doesn't know that, so it makes the conservative choice. Has to get explained on PriusChat over and over because people don't search.
    Interesting web site, that. The article has a lot of pieces of individually-true information, and useful links to a lot of the different brake-related fault analysis reports, recalls, and service campaigns. But at the same time it seems to go to great deliberate lengths to blur issues together to seem as if they are related.
    Of the NHTSA reports it quotes, the fourth one is clearly about this regen-to-ABS transition:
    This is the familiar every-Prius-ever-made oddity. It surprises people who somehow haven't been told about it, but these cars have been around 21 years now and there are plenty of people around to pass the information along. Here's my own thread asking about it 10½ years ago in the first month of owning my first Gen 1 (because it hadn't happened to me yet and I had read about it here) and having it explained to me. :) There are always some questionable explanations in circulation too, but I was lucky and got Tom's reply first.
    But back to this ToyotaTalk piece. The first three NHTSA reports it quotes are not about this issue at all, but about some very different reports where drivers say they pushed the pedal to the floor and the car kept right on going. One of them says nothing about warning lights, one says explicitly there were none, the third says there were a bunch of them.
    Those would be the kinds of "catastrophic brake failure" I'd be most interested to know more about, because (a) they don't match any of the known brake issues we usually discuss here on PriusChat and (b) they really do sound "catastrophic". I wish I knew more about them, but they seem to be rare enough we don't have much to go on here. But meanwhile this article keeps on mixing up all sorts of issues together.
    It provides a link to the "defect information report" for the A0B recall, which is the one about the regen-to-ABS transition, which apparently was more noticeable in early 2010s than in the previous generations. It says they made a "running production change in January 2010" to the ABS software to improve the response time. In February 2010 they decided to make it a recall and reflash existing cars' ABS ECUs also. My 2010 already had the newer firmware when I bought it, so I have never felt what the transition was like earlier. With the new firmware, I can vouch it feels pretty much like my Gen 1 did.
    But then the article goes on to sow confusion between this issue and the one for recall D0H. D0H was the physical recall of the pressure accumulators that could form internal hairline cracks and leak nitrogen into the system, a distinct issue from the regen-to-ABS switch. Usefully, the article links to the defect information report for D0H. I had read the TIS literature about D0H before, but never this particular report until now. It's nice to read what the underlying issue was. The accumulator in Gen 3 lies horizontally, a cylindrical can with the Slinky-like pleated metal bellows inside. Here's a metal bellows accumulator from a hydraulic equipment site (not exactly the Prius part) to show the kind of animal:
    It seems that in some of the accumulators used before September 2009 (these are the ones with the label horizontal on the can), the bellows inside was a bit smaller than the design diameter, leaving more clearance for it to be shaken up and down inside the can on bumpy roads. When shaking up and down, it hits the lower inside surface of the can hard, and that's where it forms the hairline cracks. When the bellows is closer to the design diameter, it doesn't have as much clearance to shake, and doesn't get banged as hard on the bottom of the can.
    The D0H recall was about bringing in cars with the too-shakable accumulators and replacing the accumulators with the ones with the proper internal clearance.
    ... and then the article brings in T-SB-0363-10, which was about an improvement to the ABS ECU firmware to reduce a quacking sound made by the actuator:
    Well, or you could just say they released an -06/-26 firmware version with the A0B recall to speed up the regen to ABS transition, and they later released an -08/-28 version to quiet a quacking noise? It's not like the later change for another purpose "superseded" the first one. Does the article's author somehow think the skid ECU firmware has exactly one line of code?
    The article brings in another NHTSA complaint:
    Notice what this driver is experiencing is the opposite of the first three reports (low, soft pedal with no brake response). This driver is talking about a high, hard pedal that has to be stood on to stop the car—in other words, not a loss of braking but a loss of power assist. C1391 is a code that reports either the pressure in the accumulator doesn't rise fast enough when the pump runs, or it drops too fast when the pump is stopped and the brakes aren't being used. That tends to mean something is allowing the pressurized fluid to escape back to the reservoir, maybe a release valve in the actuator that isn't fully seating. If you run out of assist pressure, the pedal is very hard; you have to make the pressure yourself. You can feel what it's like if you do the non-Techstream zero-down procedure in a Gen 1 or Gen 3. (Doesn't work in a Gen 2 because the system is different.) You know you've used all the pressure when the pedal stroke suddenly feels like you stomped on a rock.
    Next, the article wanders around to question how the D0H recall instructions could possibly have used the accumulator label orientation to tell the good ones from the shakable ones:
    ... well, um, not so far inside ... the accumulator is the black can there, the one with the label on it.
    This is funny, considering the article links right to the defect information report, where Toyota said they switched in September 2009 to an updated accumulator. And then it goes on:
    Riight, because, remember, the A0B recall was the software change to speed up the regen to ABS transition ... not anything to do with the accumulator?
    It goes on to mix up several more things, but I'm ready to call it a night. Not only is the article's author anonymous (it's written by "ToyotaTalk"), the whole web site is anonymous. It has no "about" saying here's who we are, it has a "contact" page that gives you no contacts there, only a message form you can fill in or an anonymous address to mail to. Even the domain itself, toyotatalk.com, is registered with GoDaddy under DomainsByProxy so you don't see any info of who's behind it.
    I am not a reflexive defender of Toyota in everything. The "Task X" design that came to light in the unintended-acceleration trial was legitimate facepalm material. But this article was an obvious hit piece from anonymous sources, providing links to a lot of genuine, interesting information, but mixing it up in irresponsible and tendentious ways. Yuck....
    -Chap
    davecook89t and Sporin like this.
  12. Jerry Harris
    London
    Thanks everyone for the great advise & comments. Much appreciated. This car is one trouble after another. I was driving on the motorway around 70mph & heard banging noises from engine. Lucky I was half mile to a service. Drove very slowly & parked at services. Waited for half hour & started the car. Same bangs & knocks coming from engine. Called a recovery & took back home. Next day got 3 mobile mechanics to come home & tell me what the noises were. One said that the big end bearings are gone. One said that maybe a piston is rattling. The other said that the noise is coming from the top of engine. So none of them confirmed the same twice. Put the car on another recovery truck & took it to a local reputable garage. He said that the sound is coming from the bottom of engine & could be the big end bearings. He also said that a drive belt is missing by just looking from top.
    I got a drive belt ordered from the parts shop & when he removed the air intake pipe, there was just one pulley & nothing else for the belt to go on. Not sure why there is just a single pulley. I have attached a picture of my engine code.
    I had a mini diagnostic device with me & I connected it & used Torqe Pro to get some fault codes which showed a lot of errors. Please see attached.
    As a last resort, I took it to the main dealer yesterday. They called me today & said that they also ran a diagnostic & repeated the same fault codes which I found out earlier. The exact words the service manager told me was that maybe a big end bearing slipped or is damaged. I told him of me losing about 200ml of oil every week for 600 miles. He said that the plugs were very clean & the oil could not have escaped via the PCV valve. Maybe the engine is under compression & oil is burning. I have never seen any form of smoke from my exhaust either.
    The final conclusion was that they need to start stripping the engine to get the the real problem of noise. He also said that it will be expensive. So I thanked him & took the car back home today not knowing what to do. 20181015_093022.jpg Screenshot_20181015-171057_Piston.jpg Screenshot_20181015-171107_Piston.jpg
  13. Jerry Harris
    London
    Thanks for taking the time to reply. It has 95000 miles on it. I used my OBDII scan tool with torque Pro App to get cylinder 1 misfire code.
    Thanks for the Jinx. Looks like I will need an engine swap now. :cry::cry:
    #13 Jerry Harris, Oct 16, 2018
    Mendel Leisk and Raytheeagle like this.
  14. Mendel Leisk
    41,924
    Yeah salvage engine, or sell for parts value say $500, and move on.
  15. drives
    drives Junior Member
    48
    Hampshire, U.K.
    That's really unfortunate and feel your pain and frustration. I'm also UK based and have had my 2010 Prius for coming up to three years now, with no issues thus far. Having browsed these forums for the duration of my ownership, other than some failures at really high mileages (odd head gasket etc) I don't really recall reading about any similar catastrophic failures such as yours. Are the issues potentially linked to oil usage and starvation prior to your ownership, potentially?
