causes of blown head gasket?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Psl2013, Jun 26, 2017.
  1. Psl2013
    Psl2013 New Member
    Psl
    head gasket
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Where is Psl......and what is your question really ??
    In most cases, it is impossible to tell exactly what caused a part to fail.......including head gaskets.
    Sometimes an episode of overheating causes the heads to warp.
    51,155
    factory defect
  4. danlatu
    danlatu Senior Member
    533
    1,361
    maryland
    Engine knock, too high compression, running rich, running lean, dirty injector, bad plugs, bad water pump. Has your engine had a rough idle/knocking?
  5. Mendel Leisk
    40,586
    What's the root cause of high compression, carboned-up cylinder heads? Which in turn gets back to the PCV and EGR? Ditto for dirty injectors? And rich/lean?
    I'm starting to hate those two acronyms...
    amos, Raytheeagle and Aaron Vitolins like this.
  6. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    I'll write that most blown head gaskets occur from overheating....eg driving with low or no coolant or failed water pump.
    Yes, high compression will blow a head gasket.
    In a Prius, I am not so sure excess carbon build up causing excess compression would do this, yet these cars have many of their system interwoven mechanically .
    Also, loosened (or incorrectly torqued) head bolts over time.
    Broken head bolt (can also occur from corrosion).
    Failure of the gasket near the coolant journals.
    So, a warped head being a root issue or a failed gasket....yet what caused those issues? That's the question.
    Once the head is removed I bet you'll have some leads to probably ascertain the answer.
    Let us know your findings.
    Good luck.
    danlatu, amos and Mendel Leisk like this.
  7. mikeflores2000
    mikeflores2000 Junior Member
    49
    23
    Merced, CA
    Failure to change 'lifetime coolant' every 50k 5 years otherwise coolant turns acidic eating engine parts like water pump and gasket.
