CD Player for 2001 Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by cod1951, Jul 25, 2006.
  1. cod1951
    cod1951 New Member
    I just purchased a 2001 Prius a couple of days ago. It has the standard AM/FM sterio radio with cassette player.
    I would like to add a CD player. Does the radio have a CD input? Any suggestions?
    cod1951
  2. Tideland Prius
    16,159
    I thought it had a CD player? Unless that's a Canadian feature. Check the in-dash compartment for a CD player.
  3. cod1951
    cod1951 New Member
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 26 2006, 12:56 AM) [snapback]292423[/snapback]</div>
    Definitely no CD player!
  4. Hmm, i don't know but...
    ...if you wanted to add a CD player cheaply you could get one of those tape deck adapters and plug like a walkman into it... its cheaper, less of a hassle and you don't mod the car in any way. otherwise i would say the only way is either someone will post a reply and say "yes, it does" or "no, it doesn't".
    i also haven't HEARD, but that doesn't mean its not that way, that alot of stock decks are pretty much hard wired and don't offer alot of flexablity for things like that. Explains why people like after market decks aside from they look flashier...
  5. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
    For 2001 Prius, 1CD was available as option and the 6CD changer can be swapped in. For the latter there are cabling issues to be met - if you are serious about this I'm sure we can pull together all the info.
  6. Tideland Prius
    16,159
    Must be a Canadian standard feature then.
  7. cod1951
    cod1951 New Member
    <div class='quotetop'>QUOTE(tochatihu @ Jul 27 2006, 12:53 AM) [snapback]293007[/snapback]</div>
    I am serious and would appreciate any help!
  8. jaems
    jaems New Member
    Hi all. I am serious too.
    bump
  9. tochatihu
    9,060
    3,529
    2001 Prius
    I hope that both of you can get the help you need by joining the yahoo toyota-prius group and asking the question there. Most of the active 2001-2003 Prius posters will be found there. I am in China now and somewhat distant from this issue.
  10. Frank Hudon
    Frank Hudon Senior Member
    4,147
    try Metro they used to have them. Cruise controls system also. They are here on PC.
