CD Stuck Inside Player
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Slavatheshrimp, Oct 2, 2018.
  1. Slavatheshrimp
    116
    73
    Mather
    Hey guys! What's the proper way of getting a CD out of a player if it's been stuck?
  2. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Hmmmmm. I'll love to hear the response
    Mi MIX 2S ?
  3. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Use a small tweezer to pull out the CD.
  4. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Searched and recommended try disconnect neg battery cable. Reconnect to see if it is then working again.
    Pluggo likes this.
  5. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Interestingly, this player lacks the usual pin-hole release for emergencies, but it does specifically warn against using discs that have stick-on labels. If that happens to be your case, here's a long shot: Maybe you can slide a credit card over the edge of the disc to at least make sure the label is flat where it has to be, then play for a moment to reposition the disc and use the card again. I would also keep on trying the normal eject procedure, but that's just me!
  6. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    What does the owners manual say to do if/when this happens?
  7. ASRDogman
    6,091
    3,273
    Here are a few things I found, hopefully, one will work.
    How to Remove Stuck CDs From Toyota CD Players | It Still Runs
    My prius cd-player is not ejecting cds nor is it playing them what can i do? | Yahoo Answers
    (This is not me)This happens to my 1999 Toyota Corolla's factory CD player from time to time. I just unplug the battery for about a minute, reconnected it, and then pressed the "eject" button (without turning the car on, or even inserting the key). Works every time! Good luck! :)
    This also works on a 2003 Avalon with a factory CD player and stuck CD. However, instead of disconnecting the battery, I just pulled out the "radio" fuse, which disconnects power from the unit with less hassle. Works beautifully!
    1. Turn the car off.
    2. While the car is off, hold the power and the eject button.
    3. Turn the car on.
    #7 ASRDogman, Oct 2, 2018
    Pluggo likes this.
  8. Pluggo
    608
    532
    Nothing helpful.
    "If an error message is displayed, refer to the following table and take the appropriate measures. If the problem is not rectified, take the vehicle to your Toyota dealer."
    The 'table' gives only 3 possible solutions: clean the disc, check compatibility, eject the disc.
  9. ASRDogman
    6,091
    3,273
    Clean the disc? So how are you going to do that while it is stuck in the unit???? :)
  10. Pluggo
    608
    532
    Like I said, nothing helpful is in the manual.
  11. Slavatheshrimp
    116
    73
    Mather
    Update Video! FIXED!
    Starship16 likes this.
  12. ASRDogman
    6,091
    3,273
    Why did you put 2 cd's in one slot? :)
  13. Slavatheshrimp
    116
    73
    Mather
    Lol you mean the previous owner? I’m a millennial - I don’t listen to cds
  14. ASRDogman
    6,091
    3,273
    I'm American, I have an iPhone... :)
    Glad your cd is working...
  15. Starship16
    Starship16 Senior Member
    1,348
    1,453
    Beach Christmas
    i found a credit card in mine........ :ROFLMAO: :LOL: ;)
  16. J Conner
    J Conner New Member
    25
    Austin, TX
