CEL and no heat after coolant control valve replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by dirt657, Feb 21, 2020.
  1. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Just did the coolant control valve. Lost a lot of coolant. Made sure to fill it up, then drove it, then filled it up again, then drove it. After a while noticed the CEL came on and the heater stopped working, but the car isn’t overheating. Of course both my tech stream and back up scanner are both at home and I just left for LA! Possible i crossed up the two side hoses on the control valve?
  2. dolj
    dolj Senior Member
    7,741
    3,919
    Wellington, New Zealand
    Anything is possible, and you wouldn't be the first.
    Does this pic help?
    jerrymildred and Raytheeagle like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    Sounds like you didn't get all the air out of it and there's a bubble in the heat exchanger. It takes come patience and, the time I did that job, quite a bit of squeezing of the radiator hose while the engine ran.
  4. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    But would that affect the heater? Or just why coolant isn’t circulating right.
  5. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Is there a proper write up to bleeding this system
  6. jerrymildred
    11,518
    14,124
    Tampa, FL
    I believe it can affect the heater. If there is air trapped in there, you can't get the coolant to pass throught it and offer up its heat.
    Post number four in this thread is especially helpful. 07 prius check engine light. need to bleed the air in the coolant? | PriusChat
    And there are boatloads of Youtube videos.
  7. prius8654
    prius8654 Junior Member
    Do you have a pic of how close the inverter pump and coolant control valve sit near each other? I don't see the inverter pump in this picture. I have codes: p0a93, p1116, p1121, p1123. So it looks like I'll be needing to replace both the coolant control valve and the inverter pump. I did get the red triangle while highway driving, it did go to limp mode. I pulled off and parked it. I plan on clamping off the hoses and replacing both pumps. The C0U campaign was completed in 2013, does it cover the cost for the inverter pump replacement for life? Seems like a common part to fail and the apparent redesign also fails according to the great info on luscious garage's site.
  8. ChapmanF
    15,865
    That's because that picture is of the engine cooling system, so it shows the valve, which is part of that system, but does not show the pump for the inverter cooling system, which is separate.
    Although they are plumbed into totally separate cooling systems, that valve and the pump are pretty much right next to each other in the car. If I remember right, the bracket for one of them might be holding the other one down.
    prius8654 likes this.
