CEL comes on after gas fill?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BurntWaffle69, Oct 10, 2013.
  1. BurntWaffle69
    BurntWaffle69 Junior Member
    22
    Stuart, Florida
    hey guys, I have a 2006 Toyota Prius, it has 283000 miles and still running strong on original battery and engine.
    Lately, I noticed that when I fill the gas tank the check engine light comes on after 2 days of driving. After I get under half a tank, the check engine light will turn off. the check engine light will return after 2 days of filling up.
    Other than that, there is nothing wrong with the car. And I get 55 mpg highway and 45 city.
    What is the cause of this and you think this could be a serious problem?
    thank you so much in advance have a nice day.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    You will need to get someone to read the code. Before anyone can answer your question.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    How many times in its life have you "topped off" the gas tank resulting in gas coming back up out of the fill hole?
    Gasoline belching back out?
  4. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Ema does this as well sometimes and it is especially prevelant when I put premium in her or run a bottle of STP cleaner through her with a new tank. If the code you are getting is the P0420 it is the catalytic converter that is most likely the issue. It could be the O2 sensor but most likely you are looking at a bad Cat.
    If you can post the code you are getting with the CEL I am sure you will get a lot of feedback on her with good thoughts and ideas.
    Happy driving,
    Chris
  5. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Why are you running premium?
  6. CBarr31
    436
    225
    Charlotte, NC
    Most premiums generally have more cleaning additives in them and will burn hotter. I generally try and do it every 5-10 tanks. Its especially effective filling before a long trip where I know I am going to be driving for 500+ miles. Acts as cleaner. The few tanks after a premium run are always higher MPG's for Ema.
    Chris
  7. SchmopperX
    SchmopperX New Member
    Actually higher octane fuel has a slightly lower combustible property than does lower octane fuel. High octane fuel is for high compression engines, like a sports car or a motorcycle or turbos. High octane lowers the point of combustion. It won't do you any good in the Prius, and isn't cleaner or better at all, and doesn't burn hotter.
    edthefox5 likes this.
  8. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Exactly Schmop.
  9. BurntWaffle69
    22
    Stuart, Florida
    I've never topped the tank to the point gas comes back out. Lol
