Cell phone battery drain
Discussion in 'Gen 2 Prius Audio and Electronics' started by Gaelyn37, Mar 22, 2007.
  1. Gaelyn37
    Gaelyn37 Gaelyn
    McMinnville, OR
    I have experienced a rather unusual occurence. Whenever I leave my Palm 650 Treo smartphone inside my new 2007 Prius (pkg #3) during my workday (10 hours), the phone battery drains down almost completely. Whenever I take the phone with me during the day, the phone remains fully charged. I have not used the phone in either case. Could there be some form of energy drain occuring inside the car?
    Thank you for your ideas.
    Gaelyn
  2. NCPriusNoob
    NCPriusNoob New Member
    Assuming you have bluetooth in your car. The car keeps the bluetooth connection alive with the phone so that i t can ring when there are incoming calls and be responsive when you ask it to make a call. Just having bluetooth turned on can cause a phone's battery to drain quicker, having a bluetooth connection active causes even more drain.
    One thing that surprised me is that the car appears to keep the connection going even when turned off.
  3. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    NCPriusNoob is probably right. Or your Prius is making phone calls by itself. :lol:
  4. jrfaris
    jrfaris Member
    352
    Windward Oahu
    <div class='quotetop'>QUOTE(Gaelyn @ Mar 22 2007, 06:17 AM) [snapback]410108[/snapback]</div>
    I suspected this was a Treo 650 before opening the post. We have 2 but don't generally leave them in the car when we aren't there. The Treo is known for battery drain issues. It could be related to bluetooth as indicated above but I don't believe the pairing connection would remain active if the car is turned off. More likely it is related to low signal strength. If the Treo is in a low/no signal area, it will continue to search for a signal and this results in a rapid battery drain. My wife had the problem where she worked. I bet the signal strength where you park is not as good as in your work area. Try turning the phone off if you leave it in the car, that should solve the drain problem. If so, there are programs such as Treo Helper that prevent the phone from continuously searching for a good signal.
  5. Gaelyn37
    Gaelyn37 Gaelyn
    McMinnville, OR
    <div class='quotetop'>QUOTE(jrfaris @ Mar 22 2007, 11:51 AM) [snapback]410313[/snapback]</div>
    Thanks for the ideas. I've had the bluetooth off on the Treo and my work area has just as weak a signal as does the parking spot. I'll try turning the Treo off and see if it still drains down.
  6. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Gaelyn @ Mar 22 2007, 11:55 AM) [snapback]410318[/snapback]</div>
    Just so you know, that if a phone has poor signal it will use more power to help maintain what signal it has. So if you're in a crappy signal area it will drain your battery quickly. If you want a good but illegal (hehe) demo for this turn your phone on during a long airline flight - your phone won't have any signal but it will go though a very large chuck of it's battery.
    Add that to using your bluetooth, and the 2 things can add up to a shorter battery life. Bluetooth has a negative impact to your battery life, but it's not too significant.
  7. jiepsie
    jiepsie New Member
    267
    <div class='quotetop'>QUOTE(Gaelyn @ Mar 22 2007, 03:17 PM) [snapback]410108[/snapback]</div>
    Maybe your Prius is secretly stealing power to charge its traction battery. Or maybe it's secretly calling other Priusses (Prii?) while you're at work. <_<
  8. jrfaris
    jrfaris Member
    352
    Windward Oahu
    <div class='quotetop'>QUOTE(Gaelyn @ Mar 22 2007, 10:55 AM) [snapback]410318[/snapback]</div>
    You might also like to try Treohelper. It's free and available here. It also gives you a numeric value for signal quality that might be helpful. The problem my wife had resulted from a low signal level that varied over time so her Treo kept trying to re-acquire a connection with the tower. We were able to reduce (but not eliminate) the problem by using the phone off when no coverage parameter in Treohelper.
