Cell phone charging
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by dr_rock, Dec 7, 2024.
  1. dr_rock
    dr_rock Junior Member
    36
    Pennsylvania
    I have a Prius prime 2024 with wireless charger. Unfortunatly I can't charge my Apple 16 pro with it. Is this a common issue? Any suggestions to get it to work would be great. Thanks
  2. schja01
    schja01 Senior Member
    1,809
    1,203
    Chicagoland
    2024 Prius
    Limited AWD-e
    Does the 16 Pro lie perfectly flat on the charger bed and the charger On button is in fact on?
    Since I’ve been getting Pro Max iPhones which are too large to lay flat in the charger I use the space for storing stuff.
  3. BiomedO1
    BiomedO1 Senior Member
    2,594
    1,394
    SacTown, Ca
    IMHO, Toyota's OEM wireless charging is just a gimmick. Even if you do get it to work, it'll continuously connect and disconnect as your going down the road. The only way to get reliable power into your phone is a hardwired USB cord.
  4. SFOcman
    SFOcman Junior Member
    Pinole CA
    I added a MagSafe charging puck to the slot and used Velcro so if I ever need to take it out I can. Using this setup the phone charges in the slot and I just plugged it into the usb c port in the center console area. Yeah we all know it should work without having to rig up our own fix but it’s a 45 dollar fix and it works great.
  5. SFOcman
    Pinole CA
    NewI added a MagSafe charging puck to the slot and used Velcro so if I ever need to take it out I can. Using this setup the phone charges in the slot and I just plugged it into the usb c port in the center console area. Yeah we all know it should work without having to rig up our own fix but it’s a 45 dollar fix and it works great.
  6. SFOcman
    Pinole CA
  7. Katy Koontz
    Katy Koontz New Member
    Knoxville, TN
    2024 Prius
    XLE AWD-e
    I just bought a 2024 Prius with the charging slot instead of the charging tray for the phone. But I can't find any information in the owner's manual that talks about this feature. Instead, it describes the tray, which is not a feature in my car. I want to know the meaning of the flashing and solid amber lights (I assume the solid green light means fully charged). I assume one means it's charging, and the other means it's not in the right position to charge. But which amber light is which? Also, it doesn't say if the position of the phone matters--with the charging port facing the front or rear of the car, and with the phone's screen facing the driver's side or the passenger's side. Does anyone know if I drop it in the slot any which way? Or does it have to be a particular way? I actually called Toyota and they didn't know! They confirmed that in the owner's manual for my 2024 Prius, it describes the older style charging tray, which again is not what my car has, and I think it's totally strange that they would have gotten it wrong. I also think it's strange because the 2024 models have been around for almost a whole year already. Has no one else called in to ask?
  8. Hammersmith
    Hammersmith Senior Member
    1,894
    1,883
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Page 380-386 in your owners manual.
    green - charger on, no phone detected or phone fully charged
    solid orange - phone detected and charging
    orange flashing once every second - problem between the car and charger - try turning the car off and on
    orange flashing three times in a row - communication loss with phone, charging stopped - try moving phone around in slot
    orange flashing four times in a row - overheating
    Just know that some phones just don't seem to work reliably with the charger. My Samsung Galaxy S20 happens to be one of them. I want to say one of the iPhone 13 models is also known to have issues, but I could be wrong about that.
    FLCL likes this.
  9. Hammersmith
    1,894
    1,883
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Oops. I own a Galaxy S22 that can't keep a connection with the car, not an S20.
  10. pascalvin
    pascalvin Junior Member
    2024 Prius Prime
    XSE Premium
    Not sure if its just my Prius or my imagination, but my phones (both android & apple) won't charge if I drop/push it into the slot too quickly. It'll give me that blinking orange light. I've found that by putting it in slowly/gently so that it silently touches the bottom helps it recognize/negotiate the charge, kind of like how you quietly open a doorknob. That being said, it overheats in there on 30+ min drives when I'm using Carplay so I ended up just using an oldmagsafe vent clip.
  11. FLCL
    FLCL New Member
    Georgia
    2025 Prius
    2025 Prius, S25+ Android, Qi charging slot works fine and stays connected with a silicone case. I had a thicker MagSafe case on 1st and it had issues staying connected, new case working great, no issues now.
  12. J_Henry3rd
    J_Henry3rd New Member
    Reston, VA
    2024 Prius Prime
    XSE Premium
    I tried 3 different cases with my iPhone 15 Pro Max, including one recommended by my dealer and two recommended by ChatGPT as being thin enough to allow charging in the slot in my new 2024 Prius Prime XSE Premium. None work. No matter how much I fiddle with the phone's position, I always get the orange indicator light blinking in sets of 3. Yet my phone will charge in the slot without a case and on any charging pad at home with any of those cases. So I just called Toyota Customer Support at 800-331-4331 to check on the status of my comment (Reference # 250502002977). I spoke to Lamia, who said: 1) this is a known issue; 2) Toyota is Not planning to address it; 3) Toyota will not furnish customers with a slot cover because the slot is effectively useless; 4) Toyota expects customers to take the case off their phones before putting them in the slot if the case interferes with charging because "objects" in the following sentence [at "How do I operate the wireless charging system in my vehicle?" on the Toyota Customer Support page] was meant to include phone cases: "When placing a mobile device on the wireless charging surface of the tray, it's important to make sure that there are no objects in-between the mobile device and the tray as they may interfere with charging". My question is: Who is willing to: 1) remove their case every time they put a phone in the slot; 2) carry their phone around without a case? My dealer made a big deal of this charging slot when I bought the car a few months ago. What a rip-off!
