Center Cap for aftermarket Enkei RPF1's ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Frank24, Nov 13, 2013.
  1. Frank24
    Frank24 Junior Member
    29
    Hello,
    To anyone that has the Enkei RPF1 rim (I know there are at least a few),
    what did you do about the center cap?
    The one that Enkei sells is pretty ugly and expensive. Just wondering if there are any compatible
    alternative out there. I don't know the precise size required.
    Thanks in advance
    medicinemom likes this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    You have to measure the centercap. Take two measurements. The first is the face diameter and the second is the diameter of the inside, the one that will go into the wheel.
    Once you know those dimensions, finding a centercap is easy. Here's an example of a search on eBay for 57mm centercaps:
    wheel center cap 57mm | eBay
  3. medicinemom
    medicinemom New Member
    Frank, I've done the same thing. What did you end up doing for your center caps?
  4. Frank24
    29
    Hi–
    I found these cheap ones online that fit well enough. They come in black and chrome color. I got the chrome color which matched my rims in SBC
    Results for 99081 - AmericanMuscle.com
