Center Console/Armrest Awkward Angle
Discussion in 'Gen 2 Prius Main Forum' started by Prius Newb, Aug 27, 2014.
  1. Prius Newb
    Prius Newb Junior Member
    26
    Ft Lauderdale, FL
    Loving my new-to-me 2009 Gen II, but have found the storage area under the center arm rest awkward to access. When fully opened, the cover only opens to about 80 degrees vertical or so. Because of where my seat back/shoulder/arm is positioned in relation to the cover, and the height to which the cover extends when opened, it is very awkward to reach into the storage area to retrieve anything that might be in there that I need. I actually have to lean forward in my seat and then angle my arm/hand backwards into the storage area.
    Does anyone know of, or has anyone modified their center arm rest to allow for a cover that opens past vertical or replaced the cover with something other than OEM that allows for easier access to the storage area underneath?
    Can post pictures if the above description isn't clear enough.
    #1 Prius Newb, Aug 27, 2014
    51,154
    your plenty clear, we've all been through it. i'm just not sure anyone has ever posted a mod.
  3. JC91006
    16,673
    8,518
    Unfortunately that console is not like an adjustable seat, one size does not fit all. If it's that hard to access, I would refrain from putting things in there. Or you can try moving your seat forward or backward to give you better accessibility while you're getting what you need
  4. magnumrtawd
    magnumrtawd Member
    305
    72
    Toledo,Ohio
    Your lucky..2010,s no longer have that perfect concealed carry box!!and the door storage is much smaller!
