Center Console removal to replace power outlet
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Wraiththe, Jan 8, 2022.
  1. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    I want to replace the power outlet on the "console between the seats" on the rear passenger side. I have been calling this the center console... maybe that is the wrong term...
    Anyone have any links on videos or pics to explain how to do this? I have been searching for a while and come up with nada for a gen 4 prius.
    So far I have not found any screws to remove... so thinking it must be a lego pull apart type thing.
    For the record... I really have tried to get the answer before posting the question here.
  2. Mendel Leisk
    41,926
    This may be what you need; if not lemmee know.
    Mr.Greenjeans and Rbjr like this.
  3. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    That is super awesome. Sure would like to know where you guys get this stuff from!
    Do add, the back just pulls off... as I just found out, but try to do it slowly. Cut my thumb at the cuticle... bleeding a lot for such a small cut. It resisted but came out all of a sudden.
    Now if I can find the connector at autozone.. I can replace the outlet with one of these.
    The socket does not seem to work, it seems to be too narrow inside.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,272
    880
    Monument, Colorado USA
    Good job! Yep, one thing I love about Toyota's is how much of it clicks apart/together like a big Lego set! I had to remove my wife's center console (2017 Prius) last summer for cleaning after she spilled her Starbucks coffee in there.
    Even the front grill of my 2014 Tundra just clicks apart (after removing a few bolts from the top). In the last Gen Tundra, you have to remove the front grill to replace the headlights...pretty dumb, huh? The secret is to know where the tabs are and in what direction to pull/tug so you don't break anything.
  5. Elektroingenieur
    2,515
    3,287
    Three Touring
    It’s an excerpt from an older edition of Toyota’s Repair Manual (more info).
