Center hubcap installed, finally
Discussion in 'Prime Accessories and Modifications' started by citiprius, Apr 1, 2019.
  1. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    Dael, Montgomery and Mendel Leisk like this.
  2. Mendel Leisk
    41,865
    That would be the same part for 4th Gen Prius rim too I think?
  3. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    yep took my caps off, yek, is there an o-ring seal on these? Latest price. $58 here: https://www.google.com/aclk?sa=l&ai=DChcSEwi8oNSR0fTlAhUPboYKHXQzCuQYABA0GgJ2dQ&sig=AOD64_14-y_ByrxDL7XKplosNiemwW_1UQ&ctype=5&q=&ved=0ahUKEwi2gdCR0fTlAhVExVkKHXvYBscQ2CkI3AM&adurl=
  4. Mendel Leisk
    41,865
    Just 4 little jaws as far as I know. There's a springy steel ring in behind them, compressed a little to keep a constant outwards push. The little jaws should click into groove on inside of bore, if the thing is dimensioned right.
    If they don't click into the groove, make sure the caps are not riding high somehow, that was an issue with the aftermarket 3rd gen caps I got. Was able to remedy with a little patient work with a dremel.
    Still, those look to be the real McCoy, should be good.
    Dael likes this.
  5. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
  6. mcdesign
    mcdesign Junior Member
    Lexington KY
    2018 Prius Prime
    Those are really sharp!
  7. Mendel Leisk
    41,865
    Try Amayama. Site's all in English. That part for me is $16.75 (CDN) apiece. Small items like that, usually about $10 (CDN) extra for a small mail packet. Takes a week or two.
    Dael likes this.
