Center screen Replacement
Discussion in 'Gen 2 Prius Accessories & Modifications' started by JOSHUA HERRERA, Feb 6, 2019.
  1. JOSHUA HERRERA
    JOSHUA HERRERA New Member
    Is it possible to switch out a non gps center screen for a gps center screen. Or do you have a recommendation of an aftermarket one that does the same as the oem screen?
  2. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    It is not that easy or practical to do. Search the Gen 2 forums (using More... –> Advanced Search) for at least one guy that did this. It was a lot of work, including making and installing the extra wiring looms required.
    If you want navigation, a better idea is to find a more modern head unit that is compatible with your Prius and and replace the stock head unit with that.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Why not use your smart phone that has google maps?
    Much easier and cheaper solution ;).
    Good luck and keep us posted (y).
