Ceramic Brake Pads
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BMcGraw, Mar 29, 2006.
  1. BMcGraw
    BMcGraw Member
    230
    Southern California
    Has anyone "gone that extra mile" on their US version 2nd Gen and upgraded their brake pads with ceramic replacements as shown on: http://www.autoanything.com/brakes/61A2911A0A0.aspx? If so what improvements did you notice ie. dust, stopping distance, feel etc.?
  2. jchu
    jchu New Member
    1,063
    Nampa, ID
    Don't have a clue. But hoping that most of my braking is Regen rather than Friction
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(BMcGraw @ Mar 29 2006, 05:52 PM) [snapback]232028[/snapback]</div>
    WHY? 100,000 mile brake pad life is good enough for me. Most of us have a hard time keeping the rust off of the rotors, maybe the ceramic would help with that.
  4. KTPhil
    KTPhil Active Member
    1,379
    With the computer controlling braking and regen braking, I would hesitate to change the frictional characteristics of the brakes.
  5. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    The U.S. DOJ has done instrumented studies of typical police cars and different brake pads, starting in the early 1990's. With the now-defunct Caprice Classic and the Crown Vic, ceramic pads resulted in such hard brake pedals that the average driver couldn't exert enough force to engage the ABS.
    I'll dig up the link later for the current test, which I downloaded last year. Overall, unless you *really* abuse the brakes the ceramic pads are not worth it.
  6. jayman
    13,439
    640
    Winnipeg Manitoba
    Ok the National Institute of Justice did the study:
    http://www.justnet.org/pdffiles/brakepads_epr2000.pdf
    The 2000 test is the most recent I could find. Long story short: the ceramic pads may give a "harder" brake pedal (More effort), have little if any benefit to repeated hot application, and little to any benefit to panic stop distance.
  7. Helio
    Helio Member
    173
    Columbus, OH
    I haven't switched to the ceramic pads yet, but I can tell you that I did switch to the ceramic pads available at Autozone for my GMC Sonoma (which I traded in for a Prius) and wow what a difference! Very smooth, noticeably quieter and less dust. I felt that braking was improved. Also, the dust is a much lighter color than traditional pads. I was quite impressed! I hope to try them on the Prius next week.
  8. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    apriusfan put those Hawk Performance Ceramic Pads on his Touring Prius. I think he likes them a lot. If he doesn't reply in this thread, maybe you should PM him directly.
    TireRack.com seems to rank the Hawk pads higher than other manufacturers' ceramic pads in stopping ability. As you already know, they cost around $78 online from autoanything.com:
    http://www.autoanything.com/brakes/61A2911A0A0A1903751.aspx
  9. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    isn't the stock pads ceramic?
    i was thinking of replacing with some cheap organics.. i'm still running on my first set at 107k miles.
    anyway.. when i was in kragens.. the oem replacement said ceramic.. so.. *Shrug*...
  10. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I met a salesman recently whose Prius has 230,000+ miles and never changed the brake pads. Said he didn't need to.
  11. Boo
    5,051
    483
    97
    Flushing, NY
    I don't know either. When I go to the kragen website it shows various brake pads as Prius OE - some are semi-metallic, others are ceramic.
    I do know that my Prius stock pads generate a lot less dust than my prior cars, so maybe they are a ceramic compound?
  12. V8Cobrakid
    3,790
    152
    less dust is due to regenerative braking. drive mountain roads all day long, you'll eventually see dusty front wheels. ( not a lot but noticeable)
  13. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I put ceramic pads on the front of my Camaro. A lot less dust. Braking was already outstanding, so it's hard to tell if they made it better.
    But there was much less brake dust...
