Change 2nd CD player in 2005 Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by retcool13, Jul 31, 2015.
  1. retcool13
    retcool13 Junior Member
    california
    I bought a used 2005 Prius which came with 2 CD players. One is the regular one with radio and a single cd player. The other (below it in the box) is a Toyota 6-CD changer. I guess the previous owner had a 2nd one installed as optional upgrade. Is it possible to simple replace the 2nd player with an after-market player with Aux and bluetooth?
  2. JC91006
    16,482
    8,400
    call crutchfield or visit your local electronic store. They would know much more
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    just replace the whole mess with a new aftermarket 2 din touchscreen. a metra axxess allows you to keep your steering wheel controls. there are a couple other bits and an adapter harness you will need but its an easy upgrade unless you had the jbl system. and you get all the features you want.
  4. retcool13
    california
    Thanks both of you. I was hoping to go DIY and wondering if someone did it and If I need additional cables. My main need is just an AUX.
  5. 69shovlhed
    2,170
    748
    Delaware
    the dash comes apart pretty easy; all you need is a plastic wedge, Phillips screwdriver and 10mm nut driver. several vids showing how on youtube. crutchfield can hook you up with everything you'll need, and if you buy a head unit from them they throw in instructions and some adapters.
