Change bulb in the rear number plate light ??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ksor, Feb 4, 2016.
  1. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    How do I do that on a 2008 ?
    DO I really have to dismount the inner facing af the backdoor ?
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Yes you have to remove the panel to access the bulbs. Panel is pretty easy to remove if it’s not cold.
  3. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    Ohhhh, but it IS cold here in Denmark right now ... I'll have to try anyway ;-((
    Thx for the advice !
  4. valde3
    2,002
    745
    Finland
    It’s colder here in Finland. It was -35c here couple of weeks ago... If it’s less than 10 degrees below freezing just turning the heater to max for 10…20 minutes is enough. It’s also good way to get rid of moister inside the car if after that you open all the doors.
  5. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    Can I rip the panel off with my finger (-nails) or should I use a flat wooden stick or ... ?
  6. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  7. valde3
    2,002
    745
    Finland
    I haven’t used any tools for it. But you probably need some tool to pull some clips that stay in trunk lid. Flat plaid screw driver or side cutters work fine.
    That’s gen 3.
    Sergiospl likes this.
  8. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    I have BAD experiences with LED parking lights - they burnes themselfs up with 1-2 months ... and it's illegal in Denmark.
    OK- that looks very easy ... eventhough it's cold ;-))
  9. Patrick Wong
    18,199
    6,464
    Grab a lower corner of the trim panel with your hands and pull the panel off. You may break some of the fasteners if you do this in cold weather.
    Removing the trim panel is the easy part. The hard part is going to be removing the light socket from the holder. The owner's manual shows which way to rotate the socket, but I found that to be incorrect. I ended up unbolting the license plate light assembly from the hatch, to improve my access to the sockets.
    Getting the light bulb out of the socket isn't that easy, either. You may need to use pliers with padding on the bulb glass, to remove the bulb.
  10. ksor
    ksor Junior Member
    46
    Aarhus V, Denmark
    Oooooh, I hate when these fasteners break ....
    Thx for the advice anyway !
