Change Coolant Overflow Reservoir?
Discussion in 'Gen 4 Prius Technical Discussion' started by Prius Student, Mar 10, 2024.
  1. Prius Student
    Prius Student Junior Member
    Vancouver
    2018 Prius Prime
    Hi Everyone,
    I am wondering if I would likely need a new coolant overflow reservoir? Here is what I observed so far:
    - low coolant level, all checks done when cold - level is alightly below Low line in reservoir, topped up with Toyota pink coolant and also changed the pressurized reservoir cap, then the coolant level went back to previous Low level after around 2 weeks
    - had local independent shop perform cooling system check - no external leaks found, used blue dye to check for head gasket leak, dye colour did not change (no head gasket leak suspected)
    - independent shop is aware to look inside the cabin near the passenger side and also underneath the car for the heat exchanger issue, no suspected leaks anywhere
    - had a look myself afterwards, saw some pink coolant residue on the edges of the plastic coolant reservoir tank (see photos) - should I replace the coolant reservoir tank?
    Hopefully some Prius experts would be able to share some thoughts for this unexplained coolant loss. Thanks in advance!
  2. Prius Student
    Vancouver
    2018 Prius Prime
    It’s for a 2018 Prius Prime o_O
  3. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    Clean this residue off with a sponge, and look for it to come back.
    In general, our 2016 coolant likes to settle around the Low line no matter what. The problem as I see it is if the coolant continues to drop, so just keep an eye on it.
  4. Mendel Leisk
    38,726
    4th gens have a problem with coolant leaks in the exhaust heat exchanger; something to check.
    ah, see this:
    the coolant leaks that occur in the exhaust heat exchanger result in coolant leaving via the tail pipe, as steam.
  5. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    Is that crusty red stuff around the the overflow tank in your pic at the same level as the coolant. after the coolant and leaked out?
  6. Prius Student
    Vancouver
    2018 Prius Prime
    Thanks everyone, I had the issue checked by a mechanic - found leak in the heat exchanger. I’ll consider the bypass option since there is a nationwide shortage of parts.
    Mendel Leisk and vvillovv like this.
