Change Farenheit to Celcius
Discussion in 'Gen 5 Prius Technical Discussion' started by Egidijus Zideckas, Oct 22, 2024.
  1. Egidijus Zideckas
    Egidijus Zideckas New Member
    Lithuania
    2023 Prius
    I live in Europe and have USA version Prius XLE 2023.
    I would like to change F->C in Climate module and also outside temperature in dash panel.
    It is stupid that there is no such option in settings...
    Has someone tried this mod? I think it should be doable with Techstream, but would like to know before purchasing cable.
    I know it's doable because local guy told he has done it, but he asked 200 Eur only for climate part :(
    Maybe someone would be kind enough to check in Techstream if there is such option?
    Thanks!
  2. Egidijus Zideckas
    Lithuania
    2023 Prius
    In a meanwhile I found this YT video, guy shows customizable settings, and under AC there is no such setting :(
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Why do you hate the Freedom Units???
  4. Egidijus Zideckas
    Lithuania
    2023 Prius
    I don't. Actually, I almost got used. Basically, I need to adjust +/- few degrees and leave it constant most of the time :)
    But if in future I decide to resell, I believe it would be easier with Celcius.
  5. 23PriLE
    23PriLE Member
    95
    67
    North Central Florida
    2023 Prius
    Unless the Euro version allows you to adjust temperature in increments of half a degree C the US version allows you to set the temperature more exactly. A one degree change in C is almost 2 degrees in F. If you leave it at a constant setting it doesn't really matter much. If you're too hot you turn it down and if you're too cold you turn it up regardless of the numerical display.
    I doubt that this would make it difficult to sell the car. If it allows for a finer adjustment of the interior temperature that might be considered an advantage.
  6. Mendel Leisk
    42,324
    Exactly. Mostly cargo cult. Just don't say anything, for starters. If a fahrenheit deisplay was a deal breaker, the buyer wasn't serious lol.
    A speedo that can't be revised between miles and kilometers is more serious, by far, and that was the case with 2016 model year, in North America at least. Toyota's response was to provide a conversion chart (tell owners to go pound sand).
  7. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Unsurprisingly, it does do half-degree-Celcius increments, for that reason.
    #7 KMO, Oct 27, 2024
    AndersOne likes this.
  8. AndersOne
    AndersOne Active Member
    346
    200
    Europe
    2023 Prius Prime
    Unsurprisingly a Japanese company did not forget its Japanese customers when it comes to fine grained temperature control - EU gets it as an afterthought.
  9. Mendel Leisk
    42,324
    Never used to be an issue, lol.
  10. Hammersmith
    Hammersmith Senior Member
    2,477
    2,537
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    And that image shows why the OP will probably not be able to do what he wants. The LCD screen in the climate control display is made up of individual segments. The US display just doesn't have the 0.5 increment segments. And he can't source a new climate control module from an EU car because those cars have dual zone systems and the US model doesn't.
  11. purplePriii
    purplePriii Active Member
    275
    123
    He can source one from Canada. We use celcius and the car comes with it. I could change the entire car to imperial except for the climate.
    Egidijus Zideckas likes this.
  12. Egidijus Zideckas
    Lithuania
    2023 Prius
    Well, at least one guy did conversion in my city. Here is proof in his Facebook post:
  13. AndersOne
    346
    200
    Europe
    2023 Prius Prime
    Wow, how do all these american P5s end up in Lithuania?
  14. Egidijus Zideckas
    Lithuania
    2023 Prius
    Lithuanian nation suddenly switched from VW Passat to Priuses :D
    But honestly in streets I only saw two more, so it's good feeling when everyone is watching at eye catching car :)
  15. DanyeEss
    DanyeEss New Member
    The Netherlands
    2023 Prius
    XLE AWD-e
    Hey Egidius labas!
    Did you manage to do the conversion, can you recommend someone in Kaunas
    Or Klaipēda maybe?
  16. kaictl
    kaictl New Member
    2026 Prius
    Limited AWD-e
    Did you ever get this figured out? No one seems to care about this, and this is the only post I have seen showing it to even be possible.
