Change Gearbox oil
Discussion in 'Prius c Main Forum' started by Hartish Khoobarry, Oct 18, 2020.
  1. Hartish Khoobarry
    Hartish Khoobarry Junior Member
    49
    Mauritius
    2014 Prius c
    Hi guys,
    Can someone tell me when I need to change my gear box oil?
    49,492
    in the u.s., it is lifetime. but many here who intend to keep their cars do a change at 5,000 and then every 30-40,000.
    for those who have never had it done, anytime is good, and then decide for yourself how often after that.
    the only scientific way to do it would be to be to send the old oil out for analysis at a lab.
    i'm at 70,000, and have never changed it.
    Lukey51 and Mendel Leisk like this.
  3. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    I don't think its worth changing it. The Toyota factory fills the transaxle with the fluid in a very clean environment, you will never be able to replicate such clean conditions, and due to how dirty the car is from below, junk can get in. Since the transaxle is sealed i don't see a way for exterior objects to get inside, there are a lot of Prius with the original fluid, with 100,000 miles and more, still going on the road with no problem.
  4. Mdv55
    Mdv55 Active Member
    246
    181
    Boston
  5. anas abu kaff
    anas abu kaff Junior Member
    jordan
    2015 Prius c
