Change in gas use
Discussion in 'Gen 2 Prius Main Forum' started by Robert2006, Jun 3, 2013.
  1. Robert2006
    Robert2006 Junior Member
    San Diego
    I have a 2006 prius with 160k miles on it. I am only getting about 300 miles per
    tank was getting around 350 miles. The MFD Multi Function Display says I'm
    getting about 44 mpg and when I checked the last tank by hand it come out to 35
    mpg. When driving and watching the MFD it looks like the gas engine is running
    all the time when the accelerator in depressed. Not sure if that's normal or it
    should cycle between gas/electric? Any ideas what would cause the consumption in
    gas?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You have a North American GenII, you have a fuel bladder. There is no accurate way to hand calculate tank by tank fuel consumption. The whole premise of dividing miles driven by gallons added relies on the tank being the same size. So you know how many gallons you put in because you know you had a full tank before and a full tank afterwards, and you know how many miles you drove, easy. On the GenII NA Prius, the "tank" is variable. So you know how many miles you went, but when you fill up, you have no idea how many gallons were in there the time before, and really you have no idea how many gallons are in there now.
    Is 44mpg about what you always got? Or did you use to get 50's and now it is 40's? If you drive with non-LRR tires at factory pressures, keep up with traffic, and drive on the interstate, 44mpg displayed on the MFD is actually about right.
    If you can find a nice stretch of highway, make sure your tires are pumped normally and then drive up and down about 20 minutes each way at 55mph, you should average about 48mpg to 50mpg.
    There are way too many variables to say whether or not the engine should run when accelerating. If the engine is warm and has reached S4, and the power demand low, and temperatures are good, then under low acceleration you should be able to "creep".
    cwerdna likes this.
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep. Please fill out the questionnaire.
    And agree w/2k1toaster's post. The bladder tank causes a lot of variation in manual calculations. The only way to get numbers via that is to average it over many tanks. Some values will be way below the MFD's reading for a tank and the next will be way above. It tends to alternate (e.g. 1 way below, the next is way above).
