change prius 2010 front axle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq87, Apr 25, 2017.
  1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Any one can help me with a video or pdf, to change the front axles ??
    Actually i don't want to take to any dealer
    Because they are not qualified enough to work with cars ..
  2. Former Member 68813
    3,524
    983
    US
    The procedure is similar in all FWD cars, but late Toyotas are tough due to staked axle nuts. I'm facing the same job, but will try to repack grease first in case that works. What are your symptoms and miles?
    Tariq87 likes this.
  3. Former Member 68813
    3,524
    983
    US
    Another thought. Read the wheel bearing instructions. The most difficult step is common for both repairs. Maybe even it's worth to do both?
    Tariq87 likes this.
  4. Mendel Leisk
    40,576
    Repair Manual info:
    Brian in Tucson likes this.
  5. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I replaced an axle on a 2010 yesterday. The manual excerpt you posted made it easy-peasy. Autozone, btw, loans a slid hammer kit that works like a charm. Comes in a black case, # 648611T, deposit is $125 plus tax.
    Thanks Mendel!
