Change the brake pads
Discussion in 'Prius c Main Forum' started by zmarcoz, Aug 6, 2020.
Tags:
  1. zmarcoz
    zmarcoz Junior Member
    22
    How much would it normally cost for both axis?
    Also a mechanic asked me whether I would change the rotor? Should I do that too? How much would it cost normally?
    Prius C 2013
    52,393
    pads = $200.
    rotors = $400.
    how many miles on her?
  3. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Most cases rotors don’t need replacing unless you have had like two or three brake pad changes already.
    Mendel Leisk and zmarcoz like this.
  4. zmarcoz
    22
    $200 per axle? or both?
    130,000 miles without any change before
  5. bisco
    52,393
    both. the rotors should be inspected, and only replaced if necessary
  6. Mendel Leisk
    41,906
    The c rears are drums, tend to last a long time with dust blow out and relube of contact points, not much too it. .
