Change tire size to offset speedometer error?
Discussion in 'Gen 3 Prius Main Forum' started by mysticeyes, Jul 27, 2017.
  1. mysticeyes
    mysticeyes Junior Member
    Maryland USA
    Hello everyone. I'm the second owner of a 2015 Prius Three in beautiful condition. I've noticed that the speedometer reads about 2 mph higher than speed reported by GPS at ~ 55mph, about a 3% difference. A 205/75-15 tire would offset most of that difference, but tires of that size offer very few choices. Now a 205/60-16 tire is about 2.8% taller, with much better variety in tire designs. I know that somewhere in the basement I have a set of 16x7 wheels, originally off a Subaru WRX with a 5x100 bolt circle and 45mm offset, and that weigh about 11-12 lbs. apiece. I'm thinking about trying a wheel on the Prius to see if it rubs against anything. But I've also read the following in an old thread here:
    "Increasing the rolling circumference in a manual car can improve mpg by reducing engine revs for a given speed. With the Prius transmission this is not the case as engine revs are likely to increase with an increase in torque load that a larger circumference will produce."
    So what do you think? Worth trying?
    #1 mysticeyes, Jul 27, 2017
  2. Mendel Leisk
    38,713
    Absolutely.... not.
  3. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    My advice: Don't worry,:whistle::whistle::whistle::whistle::whistle: be happy! :whistle::whistle::whistle::whistle::whistle:
    …seriously, though you might experiment with the tyre pressures, just remember to set the hinds at 2 PSI less than the fores (…well, that's what is recommended!)
    Here's a link which might be useful:
    Tire Size Calculator - Tire & Wheel Plus Sizing
    Good luck! ;)
  4. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
    Why are you so sure the GPS is more accurate than you speedometer?
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Seconded. Positively, absolutely not!
  6. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Because IT IS
    GPS is the most accurate speed you can get
    Speedometer is PROGRAMMED to lie
  7. Mendel Leisk
    38,713
    If the speedometer indicates (for example) 50 mph, when in fact you're travelling 48 mph, what are the implications? That you're travelling 2 mph slower than indicated. That's about it.
    Not exactly a big problem, nor insurmountable. You could:
    1. Drive 52 mph, be spot-on the speed limit.
    2. Drive 50 mph.
  8. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    OP, OCD much? ;)
  9. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    @bwilson4web did something similar with his Gen 1 Prius, I think. He is our measurement expert and can more intelligently explain his testing.
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, it's the -odometer- that is important accuracy wise. I suspect you will find it is almost right on. As posted above, speedometers are often set high intentionally. To keep you from getting -as many- tickets I suppose. Larger tires can certainly offset the speedometer error, but they can actually be illegal in -some- jurisdictions.
  11. Mendel Leisk
    38,713
    I'm not checking my facts, but I believe the purpose was to try to slow people down, reduce injury severity, and fatalities. You never want to have a speedo that reads low, deadly accurate is an impossibility, so reading a bit high was mandated.
  12. MelonPrius
    MelonPrius Senior Member
    821
    509
    Las Vegas
    Larger tires would fix the speedometer issue. But I believe it would then make the odometer less accurate. The actual mpg (both hand calculated and with the computer) would be ~3% lower because the car would travel further than the odometer would indicate.
