Changed battery and dropped socket? Dangerous?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TOY0TA FAN, Jan 20, 2014.
  1. TOY0TA FAN
    TOY0TA FAN Junior Member
    44
    Dallas, TX
    I was changing my 12v and was putting the negative lead back and the alarm sounded. It scared me a little and I dropped the socket but the bolt was secure. Is it safe to leave the small socket in their? It fell in the battery tray on the very bottom.
  2. JC91006
    16,673
    8,518
    There shouldn't be any danger but why don't you just remove the battery and take it out? It's just a 10mm socket.
  3. Rich12
    Rich12 Member
    176
    29
    He sounds about as competent as I am when it comes to wrenchin' :LOL:
  4. TOY0TA FAN
    44
    Dallas, TX
    It seems like too much work took me forever to take the battery out and it was hot outside. Anyway thanks for letting me know.
  5. JC91006
    16,673
    8,518
    there are no moving parts there, it's safe.
  6. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,151
    1,701
    Mars Hotel
    Could bounce around and make noise on occassion.
    I would obsess over it being there, even if I never heard it....:rolleyes:
  7. Patrick Wong
    18,200
    6,493
    This is why it is helpful to have a collapsible wand with a magnetic tip. If you are lucky, you will be able to pick up the socket with such a tool, without having to go to the trouble of removing the battery a second time.
    Should you go to the effort of removing the battery a second time, you will benefit from a learning curve and this may encourage you to be more careful as you are working in that area...
    However if you decide to leave the socket in there, it is not the end of the world.
    cyberpriusII likes this.
  8. cyberpriusII
    1,151
    1,701
    Mars Hotel
    Agree on both points. Bought the wand before replacing my 12V a couple of weeks ago. Don's instructions had me gunshy about losing the vent tunnel bolt (http://priuschat.com/attachments/gen-ii-12-volt-battery-change-pdf.61223/).
