Changed brakes and rotors.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by msg4life, Jul 30, 2021.
  1. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    So for my 100k maintenence I changed brake pads... they still had so much meat but I was fine with that didn't change rotors at first.. then had grinding and squeeling.. I bought factory oem rotors squeeling and grinding went away... but the trick here is I bought the rotors from a lexus dealership they were a lot cheaper than all Toyota dealerships.. as a tip if you have the part number check lexus dealerships. Might save you 50 bucks like me.
    51,141
    thanks for the great tip!(y)
