Changed oil and flushed ATF fluid - May have broke car; making weird noises, car shuddering
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SRQ, Apr 4, 2014.
  1. SRQ
    SRQ Member
    158
    56
    I did some maintenance today:
    1. Changed oil
    2. Flushed ATF fluid
    3. Cleaned throttle body
    4. Cleaned MAF sensor
    I did all of these one right after the other and when I rolled out to test drive, the car shuddered and now the engine is making weird noises. I don't want to turn the car on again or drive it. I'm thinking the issue may be that the transmission isn't sealed properly (I may have put the screw in sideways) but obviously something is clearly wrong here.
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    This is not meant as an insult. Really.
    If you think not properly seating the transmission drain screw will make the car run bad......just at idle......then you are clearly in WAY over your head skill wise and need to get it to a qualified shop for diagnosis.
    Before you do that, you might want to start it one more time. It might "magically" run much better.
    Then if it does, you can drive it in to have the transmission screw checked.
  3. xliderider
    xliderider Senior Member
    8,056
    3,224
    Honolulu, HI
