Changed oil; disagree with posted instructions :)
Discussion in 'Gen 2 Prius Main Forum' started by cyberprius, Feb 11, 2008.
  1. cyberprius
    cyberprius Mtn Bikes don't need foglights
    185
    oregon
    My Prius just hit 1,000 miles so I decided to change the oil. Normally my husband would do it, but I told him he couldn't touch my car after smacking up the bumper at 400 miles. Apparently he took that to mean oil changes also :(
    I looked over the instructions I found here and everyone talked about having to jack up the car. I don't know why, I found it fairly easy to do with the car just on all four tires. Everything is right up front.
    Now, if someone could tell me why the car has to have "3.9 quarts of oil..." That taxed my math skills a bit. And now what do I do with the extra four ounces :p
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    662
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Lawnmower:rolleyes:
    Congrats on doing it yourself.
  3. HOVZOOM
    HOVZOOM New Member
    37
    Fairfax, VA
    2002 Prius
    Lawn mower uses a different viscosity - save it for your next Prius oil change. I do not jack up my 2002 either. Very easy oil and filter change on this car.
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I jack up the drivers' side a *little* bit just to get a little
    extra working room underneath. That not only raises the front
    end a few inches, it tilts toward the direction of oil drain,
    but really only unweights the springs a little and doesn't pick
    the entire car off the ground.
    _H*
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    My first change also was done with the car on the ground. But I'm a pretty big guy, and it was nice to have the extra room that ramps provide. I put them on a downhill stretch of the yard -- to keep the car level front-to-back -- and stagger them so that, like with Hobbit's method, the driver's side is higher.
    Regardless, congrats on your first oil change!
  6. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    I must be fat.
    Or claustrophobic.
    Or both(?).
    I'm definitely a jacker-upper.
    And just put 3.5 quarts in. And put the calculator away. Eyeball measure
    works pretty good for me.
    Cool avatar, by the way.
  7. cyberprius
    185
    oregon
    I think next time I will go for the 3.5 quart measure. Also, I think I will use a paper funnel. I got tired of pouring 6 ounces into an empty jug and carefully pouring into the oil filler hole!
    Of course, next time, maybe I can talk my husband into doing it. On the other hand, not sure I trust him. I can just see a few big oily handprints on the bumper and hood!
    As for my pix, I was going for the treehugger look, that was the closest I could find among my stashed photos!! Only thing is, in the background you can see my mountain bike instead of my Prius...of course the picture was taken several months before I HAD a Prius.
  8. hobbit
    4,089
    468
    Bahstahn
    Oh, right, the other trick -- if you remove the top cover from
    the air box and pull out the filter, you open up enough room
    for the bottom end of the oil bottle as you start tipping it
    to pour into the fill hole. Eliminates any need for the funnel
    if you're careful, although I still pack part of a rag around
    the fill hole to catch anything if I miss at the beginning of
    the pour.
    _H*
  9. dogfriend
    7,512
    1,189
    Carmichael, CA
    I have found that 3.5 qts puts the level about 3/4 distance between the low and full marks on the dipstick. Which is good. I think about 3.7 qts would be right at full. 3.9 qts would be too high.
    I had the dealership do the first oil change - they filled it too high and left the aforementioned oily fingerprints on the air cleaner housing. Now I change it myself, but I do use the ramps - I'm too thick to make it easily otherwise + I can inspect the CV boots, etc. while I'm under there.
  10. cyberprius
    185
    oregon
    Thanks so much for the tip!!!
    It was a real "exercise" to try to get the quart oil container lined up for my "virgin" first pour. For the first quart, I am sure about an ounce missed the filler hole and ran down the front of the engine.
    After that I just poured a few ounces at a time into the first bottle, but it was a frustrating exercise. I'll be sure to try the filter trick next time!
  11. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    I just use a funnel and 3.5 quarts. That's plenty of oil.
  12. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    Congrats. But, why did you change oil at 1000 miles? It is supposed to be done every 5000 miles.
  13. cyberprius
    185
    oregon
    There is lots of disagreement on changing at 1K. Many people, my dad and husband among them, say that while manufacturing processes have improved tremendously in the past couple of decades, there is still a chance of "manufacturing" left-overs being left behind in the engine.
    They claim it is cheap insurance to swap out the oil and any "supposed" leftover nuts, bolts, screws and metal filings at 1K. Cost me less than $12, so I decided to play it safe. Next oil change is planned for 5K and then every 3K after. I know, earlier than Toyota says. But my family has had Toyotas for more than 30 years. All of them have gone 300,000 miles plus (well, except for the celica my brother totalled) on 3K oil changes, so I will continue the tradition.
    Plus, as my husband said, and as one previous poster mentioned, gives you a chance to look over the underside of the car....now I just have to learn why a "boot" is under my car and not on the foot of a local ranch-hand!
  14. Qlara
    Qlara New Member
    488
    Though 1k miles seems too early even for the break-in oil, congrat on your first oil change! Did you switch to Synthetic as well as using other oil filter (or OEM still)?
    I'm still running my break-in oil, but I plan to change around 2k instead to utilize the oil and the filter for rinsing first.
  15. cyberprius
    185
    oregon
    As I understand it, the oil in the Prius is just "regular" oil when the car comes straight from the factory, not a special break-in oil. I could be wrong, but thought that my readings had indicated this. But, I have read so many things....
    I used a Purolator Premium Plus filter, which is what we use on all our cars....It was on sale for $3.29 yesterday. Used three quarts of Quaker State 5W-30 and a quart of Pennzoil. The "wisdom" in our family is against synthethic oil. Many others disagree!
  16. dogfriend
    7,512
    1,189
    Carmichael, CA
    Constant Velocity (CV) joints have a rubber "boot" which keeps the grease in and dirt out of the joint. You can find one at each end of the axle for a total of 4 CV boots. If you find a tear in one of the boots early enough, it may be possible to repair it before the CV joint is damaged.
    Also, the ball joints and tie rod ends have a rubber boot for the same reason (to keep grease in and dirt out). These can't be replaced without replacing the ball joint or tie rod end.
    Finally, there is a boot on each end of the steering rack to keep dirt out.
  17. Sonny Jim
    Sonny Jim New Member
    260
    Newport Beach, CA
    Re: :)
    Sounds as if you are on the right track with maintenance; I also agree with you regarding conventional oil.
    What color Prius did you get? As you and another poster mentioned, you have a fun avatar and maybe it's time to re-shoot it with the Prius in the background :D
  18. Qlara
    Qlara New Member
    488
    Quite right, it's just regular oil.
    I simply refer the first oil in (any) new car as 'break-in' oil anyway....as you mentioned, engines may have some 'dirt' left over during manufacturing and running during the first couple of thousand miles. So I'll wait for this oil/filter to rinse off and filter out as much dirty stuff before I change it to something else for longer haul.
  19. BlackPri08
    BlackPri08 New Member
    50
    central Indiana
    I went to a new owners clinic at my Toyota dealer. They told us that the oil that comes in a new Toyota is heavier, as well as having certain additives. They also advised against changing it before 5,000 miles (sorry cyberprius). They say the oil helps in the break-in perioid.
  20. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Interesting. My dealer gave me a complimentary 1K oil change to assure cleanout of metal shavings, similar to what Cyberprius cites:
