Changing 2004 Prius Hybrid Battery Cells
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Slight, Mar 13, 2017.
  1. Slight
    Slight New Member
    South Florida
    OK, i have tore the battery out, and i have volted them all out, and have written the voltage on the individual cells. I think there are 4 POSSSIBLY 5 that need to be changed. I need some expert advice or some educated indication that the 3-4 that i think are bad, well actually are.
    Attached is a pic of the individual cells and the voltage. (i know the terminals need to be cleaned)
    Ok, i think there are 4 possibly 5. they are indicated by a big RED dot under the voltages. i really dont know if the 6.85 needs to be changed or charged. ( i think change)
    any and ALL advice is welcome.
  2. JC91006
    16,496
    8,406
    That entire pack needs to be charged up and then tested. They are all under the minimum 7.2v.
    The best way to do this is to buy a grid charger from hybridautomotive.com and charge them all up. This will be close to a $500 investment but it'll be the right way to rebuild the batteries.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    My that's a lot of corrosion on the end terminals; even the case studs have it. Spend a lot time at the beach or with the windows open?
  4. JC91006
    16,496
    8,406
    The modules might all still be good, just discharged. The bus bars definitely needs to be all cleaned up. You need to do a full charge of the entire pack, then you can tell if they are all good or not.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,337
    6,013
    Columbia, SC
    Slight,
    I agree with JC1006. Although the pack is quite discharged, they may all be good (or they may ALL be sh*t). I've seen modules worse than that fully recover after cycling and testing. Although you have a few that are in the 6.x range, it's not a done deal that they are bad. I've also seen plenty that are at 7.5 volts and have <1000mha capacity.
    I'd also pull the bus bar strips off and check them again with the meter leads directly on the module terminals.
    Or find yourself a newer wrecked Gen 3 battery to buy, swap out the modules and be done with it. Saves money on test equipment and gets you modules that are probably good for another decade.
  6. Slight
    Slight New Member
    South Florida
    I live in Florida, there HAS to be a cheaper way to charge these cells. what current @ amp do u need to charge these with? Ill keep an eye on them till 7.8 then see what they drop to after ii let them sit for a half day. the bad one will stand out. but a charger....... the CHEAP method, till i successfully do this, then other funds could be allocated for the upcoming projects.
    The corrosion i am going to go get some supplies to clean them with. I do know over time, copper looses its conductivity, so a replacement of the bus bars may help a little????
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    And for the other side of the coin........
    If you really do have a few cells that have failed due to age and use, I think it is a fools errand to change them out, unless maybe you have nothing better to do with your time BECAUSE soon after you get it back together it is likely that a few others will fail........and this cycle will be repeated over and over until they ALL are new. Might as well do them all at once, if and when you have more than one that actually fails.
  8. Sam Spade
    2,036
    1,023
    2017 Prius c
    Complete and total BS.
    How exactly do you think you "know" that ??
  9. bisco
    49,720
    some people use a hobby charger. i've seen the models in other battery threads.
    btw, can a mod please move this to the newly created battery thread?:whistle:
  10. JC91006
    16,496
    8,406
    You can get more information about charging and reconditioning modules at hybridautomotive.com
    You can recondition with hobby chargers but that will take you a month to recondition an entire pack. If you use a grid charger, it'll take less than a week.
    You should also make sure the battery is properly cooled when you are charging them, if they overheat, they'll expand and start leaking.
