Changing a lightbulb what could possibly go wrong... ugh
Discussion in 'Gen 2 Prius Accessories & Modifications' started by wwinters, Aug 16, 2015.
  1. wwinters
    wwinters Junior Member
    31
    Long Beach, Ca
    This should have been a quick easy mod., change the interior lights with LED's. I took off the overhead light cover and tried to remove the first bulb but it wouldn't come out so I wiggled it a little and pushed and pulled a little next thing I know the light has popped back into the console and is nowhere to be found. Looking closer, I know what I did but now need to figure out how to get into that part of the the overhead console to put the light back in place and maybe some suggestions how to pull the bulb out once I've fixed my mistake.
    Update- the other two bulbs came out easily and work great with the LED's
    #1 wwinters, Aug 16, 2015
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    this is why Toyota charges $100 an hour for labor, they are TRAINED bulb replacement engineer's...
    my guess is the part that holds the bulbs will pop out if you move the clips towards the outer edge, of course they may break off and the light will hang down from now until doomsday ..
    maybe a video on youtube will save you, its worth a look
  3. wwinters
    31
    Long Beach, Ca
    looks like I need to go buy molding remover tool, what could possibly go wrong...
    #4 wwinters, Aug 16, 2015
  4. frodoz737
    frodoz737 Top Wrench
    4,726
    2,518
    33
    This is 2010, but should be close.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Can I be the first to ask "How many Prius Owners does it take to screw in a light bulb?"
    valde3 and wwinters like this.
  6. frodoz737
    4,726
    2,518
    33
    Post #7 and counting.
    Burna J likes this.
  7. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    LED lighting now... (y)
    See what happens when you come over for one of our Mod Parties. Should I get with @sfv41901 and schedule you in for a lowering next.
    Just kidding.... :)
    wwinters likes this.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    "How hard can it be?" and "What could possibly go wrong?" are always introductions to good stories. I hope this one turns out well.
  9. wwinters
    31
    Long Beach, Ca
    I think he's going to do the bosectamy on my 99 miata first then maybe we'll lower the Prius and add power folding mirrors.
    Burna J likes this.
  10. Southpaw1969
    Southpaw1969 New Member
    22
    SoCal
    Ugh, I did the exact same thing on my 2007!
    How can we get those clips holding the assembly in place out? I'm afraid of breaking the thing and ruining it.
    I couldn't find a YouTube video on this. Anyone know of one?
  11. Beachbummm
    1,160
    392
    no one has ever done it so the world may never know
  12. JimInRadfordVA
    JimInRadfordVA Junior Member
    Radford, VA
    Don't panic!
    I had the same thing happen to me. If I recall correctly, all I needed to do was pull down the entire housing and twist the socket back in. If you look closely, you may find a screw or two to remove first.
    Replacing the interior lights, the back-up lights and the live de plate lights was well worth the effort. The cost was negligible.
    Let us know what happens.
  13. wwinters
    31
    Long Beach, Ca
    Finally got around to removing the housing. There were two screws in the sunglass compartment that needed to be undone then piece popped off without even needing to use the wedge tool I bought. I found the light socket rolling around (I assumed the light sockets were connected by wires but they weren't, securing the socket to the board completes the circuit) It was a very easy fix and the lights look good.
    frodoz737, valde3 and Burna J like this.
  14. wwinters
    31
    Long Beach, Ca
    If you're talking about the white-ish plastic circle clips by the lights in my first picture,this stumped me also, they don't need to be removed. In my 06 there are two philips screws you'll see when you open the sun glass holder, unscrew these and use a molding tool (or I just gently pulled with my hands)to bring it down. My setup looked like what Valde3's posted.
