Changing Break fluid
Discussion in 'Gen 3 Prius Technical Discussion' started by Manhal K Alrashdan, Apr 26, 2017.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    I wonder if I should change my break fluid . I already have 150k on without changing the fluid. It looks transparent and clear .
    49,492
    probably a good idea, but you don't have any humidity there, do you? any recommendation in the o/m?
  3. b100
    b100 Member
    141
    73
    Netherlands
    Test it with a brake fluid tester, if its good? Let it be there. Toyota brake systems are sealed verry well, on sone cars the fluid can go 15 years without changing it.
