changing cabin air filter on own ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by arayan, Jan 17, 2013.
  1. arayan
    arayan Junior Member
    UK
    my nearby toyota garage wants to charge me 35-40 pounds ($56-64) to change my cabin air filter
    i tried once to change it myself, but ended up 1) jamming the glove box 2) putting in the wrong filter
    does anyone know what the model number of the filter is and where i might find it exactly
  2. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    Try Amazon...
    FRAM CF10285 Fresh Breeze Cabin Air Filter : Amazon.com : Automotive
    F8L likes this.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Walmart and most automotive stores will also carry the filter. Walmart has a small computer where you enter your car make and model and it will give you a list of filters that fit your car, including the FRAM mentioned above.
    As for the change, the trick is to remove the damper rod on the right side that holds the glove box when open and then remove one side of the glove box at a time by pressing in on the side to clear a plastic tab at the back.
    There are instructions for doing this in the Owner's Manual. Also search on here as someone just posted a How To video in another thread.
    car78412 and F8L like this.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    In addition the the Fram number listed above here are two Toyota numbers: 87139-YZZ08 and 87139-YZZ10. The YZZ10 is more expensive and a better filter but the YZZ08 is good enough for most conditions.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I did the exact same thing the first time. Ended up breaking the tabs that hold it closed! I was able to do surgery and glue things back together though.
  6. El Dobro
    El Dobro A Member
    6,978
    3,213
  7. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Arrows go up on the filter?
  8. ETP
    2,801
    1,170
    Auburdale FL
    Also the dealer jammed it in backwards so a good thing I checked it today.
  9. Mendel Leisk
    38,651
    The OEM cabin air filter has an arrow with the word "UP", so no confusion. I believe a lot of aftermarket filters have sim. arrow with word "FLOW" or "AIR FLOW", something like that. Which can cause confusion: it's not readily obvious what direction the air flows.
    I suspect the new filter could be put in with either side up, that it makes no difference. It becomes important tho, if you remove, dust off and re-install a used filter: you don't want to reverse direction then, precipitate a dump of accumulated dust, lol.
  10. ETP
    2,801
    1,170
    Auburdale FL
    Thanks, I did the arrows up. The dealer put the arrows on the sides. ARGH!
  11. Mendel Leisk
    38,651
    Is it square? Maybe.
  12. El Dobro
    El Dobro A Member
    6,978
    3,213
    Actually, it's quite groovy. Go Baby!
  13. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    Air flows DOWN through the filter, otherwise how would it capture any debris?
    Toyota OEM filter has arrow and says UP, Fram filter, IIRC, has an arrow and says FLOW.
    As far as the dealer inserting it incorrectly, I would find a new dealer (and pity their spouse :LOL:.)
  14. ETP
    2,801
    1,170
    Auburdale FL
    Square but the front and back are reinforced. It does not fit right backwards but upside down fine.
    If you put it in upside down it catches the small particles first and the big ones last. Not sure it makes any difference but they are both installed upside down//Maybe //but not backwards or inside out.:unsure::confused:o_O
    Next time I will remember to install then backwards, inside out, and arrows down.:LOL::LOL:
    #14 ETP, Jul 18, 2015
  15. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Yes.
    Sideways --- Will allow more air to bypass the filter, but better than nothing.
    Upside-down (=inside-out) --- Probably OK for most NEW (as Mendel points out) filters. Some, depending on construction, might be a little less efficient than if rightside-up.
    Toyota's "UP" arrow counter to the (perfectly obvious) flow direction begins to seem an unnecessary source of confusion.
