Changing Defaults on Gen IIIs
Discussion in 'Gen 3 Prius Technical Discussion' started by hansgrason1, Jun 10, 2010.
  1. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    Hi all,
    The default when putting the car in 'P' is to have all doors unlock automatically. I really don't like this and have been trying to understand just WHAT the owner's manual is talking about when it explains changing the default action when the car is placed in 'P'.
    Has anyone else been able to follow these directions, and if so, would you mind explaining it to me?
    Thanks!
    P.S. what I am ideally trying to do is to reprogram the door locks so that they STAY LOCKED after the car is put in park ('P').
    Thanks!!!
  2. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
    Sorry but European Prius aren't equipped with this system.
  3. Dan bo
    Dan bo Prius Fan
    116
    34
    28
    Canada, London
    Hi I wanted the same thing and took it to my dealer who fixed it in under 5 minutes. I don't believe you can change it yourself.
    Edit: The dealer hooked up a laptop to make the change, it plugs in just under the steering column. Pretty easy and fast fix.
    Oh yes, he didn't charge anything either.
  4. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    You can only change it at the dealer with a computer hooked into the Prius
  5. Tideland Prius
    16,445
    There are 3 settings
    Default - Shift out of Park = lock, Shift into Park = unlock
    Option 1 - Shift out of Park = lock, Open driver's door = unlock (this is the one you want, right?)
    Option 2 - Speed sensitive
    In older Toyota models, it is possible to program it yourself by pressing the LOCK and PANIC button simultaneously. I haven't tried it with the Gen 3.
  6. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    I think at the dealer they have the option of also changing these settings using a specialized laptop application, but the user guide does give instructions on how the owner can make the changes. I had a Camry a few years back and had no trouble changing many of the default settings by following the same type of instructions in the owners manual.
    For some reason though the Prius instructions are not very easy to follow -- to me anyway.
  7. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    The dealer can use a laptop application from Toyota to do it eaiser, granted, but if you go to section in the Owners Manual entitled: Automatic door locking and unlocking systems: Setting and canceling the functions -- you will find the sequence of steps to undo and redo factory settings -- This is in SECTION 1-3, Pages 69 and 70 in the U.S. Owners Manual.
    There is also a way to use the remote (FOB) to open the back door (hatch) from outside the car ... I aint figured that out yet either ... anyone else firgure this out?
    Thanks!
  8. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    Yes, option #1, exactly! This is what is outlined in the Owners Manual as being an option that the owner can perform.
    Also, how do you use the remote to open the back door (hatch) from outside the car?
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    Have you tried the procedure in the manual?
    For the remote, if you press the unlock button on the FOB it will unlock all of the doors like most other remote key unlock FOBs. Then you open the hatch with the rubber button like normal.
  10. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    Yes I have. Like I said in my message that started this thread, " ... have been trying to understand just WHAT the owner's manual is talking about when it explains changing the default action when the car is placed in 'P'. "
    What I'm looking for here is someone who has successfully tried the procedure in the manual and can explain it to me better than the manual explains it.
  11. jamesrlaw
    jamesrlaw Two Timer
    Phoenix
    Well that should be almost any person on earth. Hard to believe you could cut down a tree and produce this many books with this many pages and be this bad at writing directions. They apparently think putting a picture of something and then labeling it is giving directions for how to use it.
  12. jdcollins5
    5,131
    1,342
    Wilmington, NC
    I agree that the manual is not very easy to understand AND I have not done this myself, but reading the manual I would interpret this to mean the following:
    Step 1) Close all the doors and switch the “POWER” switch to ON
    mode. (Perform Step 2 A & B within 20 seconds.)
    STEP
    Step 2A) To change the shifting to Park from unlock to remain locked: ​
    Press P (Park) button AND the Door Unlock button for 5 seconds - this should cancel the original setting of unlocking the door when pressing Park, which should then convert to remaining locked.​
    Step 2B ) To change the unlock function to opening the driver's door within 10 seconds of powering down:​
    Shift lever to N AND press the Door Unlock button for 5 seconds - this should cancel the original setting of doing nothing when opening the driver's door, which should covert to unlocking the doors. ​
    Try this. If this does not work, I would suggest calling the dealer and see if they can explain it!​
  13. Tideland Prius
    16,445
    After reading those two pages, it seems pretty straightforward. If you want to change the lock settings, you use the P, if you want to change the unlock settings, you use the N position
