changing engine thermostat 2007
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Flapper314, Jan 27, 2014.
  1. Flapper314
    Flapper314 New Member
    Hello,
    Was wondering if any one has ever changed a thermostat on a 2007 prius?
    I have a mechanic friend of mine that is going to help me change mine. Just had a few questions
    before doing it.
    Where is it located? Is at the bottom of the engine block ? ( been a long time since I have done one since my 1983 oldsmobile and that one was on top and nothing was on the way !).
    I did some research about bleeding the cooling system after changing it to get all the air out of cooling system. There is a hex bolt on top of radiator.
    Any insight is greatly appreciated !
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved out of the Prius v maint. forum to the Gen II maint. forum
  3. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    Welcome to PC.
    If you are going to replace the thermostat I would also replace the coolant pump and belt while you have the coolant drained. Instructions in the link below.
    How to replace engine coolant pump and thermostat | PriusChat
    John (Britprius)
    It would be helpful if you put your location in your avatar as this helps us help you.
    I assume your in the US in which case the pump is available aftermarket for around $40, and the belt $10. Only use Toyota SLLC coolant when re filling the radiator,
    John (Britprius)
  4. K8A
    K8A New Member
    Boise
    I know this post is old, but I made a video showing how to change the thermostat. Hopefully it's gonna help a few people.
    Raytheeagle and bisco like this.
  5. bisco
    49,397
    always helpful, thank you!(y)
