Changing fluids
Discussion in 'Generation 1 Prius Discussion' started by adric22, Jan 6, 2010.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    I'm looking to change out the following on the 2002 Prius:
    • Oil
    • Transaxle
    • Coolant
    I checked with a local dealer and they want to charge $21 for the oil, which is reasonable, but they want $125 for the coolant and $165 for the transaxle. That sounds a little ridiculous. I was thinking of doing it myself. I've done it before on other vehicles, but never a Prius. Is there anything I should know about doing this? Any particular brand or place I should buy the fluids?
  2. Patrick Wong
    18,210
    6,511
    Engine Oil: 5W-30 viscosity, whatever brand you are comfortable with
    Transaxle: Toyota ATF T-IV, five US quarts needed
    Coolant: Toyota Super Long Life Coolant, at least two, maybe three gallons needed
    Transaxle ATF fluid change is easy, do a search for info. Need 24 mm socket and funnel with 3 ft. flexible tail.
    Engine Coolant is like any other car, look for the radiator drain and the engine block drain on the side of the engine facing the firewall.
    Inverter Coolant is not easy, do a search for info. Listen to the sound of the inverter coolant pump when the car is IG-ON. After you replace the fluid you have to work at getting the air out until the pump sounds the same again. Good luck.
  3. tochatihu
    tochatihu Senior Member
    9,850
    3,806
    Kunming Yunnan China
    2001 Prius
    Based on Adric's price quotes, throw $125 at the coolants unless you want to learn how to do this right. The other two are not difficult DIY.
  4. kenopa
    kenopa Junior Member
    57
    Indiana
    Because it's too cold, I had dealer change both coolants in Dec at 120,000 miles instead of doing it myself. Cost was $115. With Toyota coolant at about $17 per gallon, that price was about what I expected for the service.
  5. dswi
    dswi Junior Member
    31
    Greenville, South Carolina
    2001 Prius
    Are the dealer coolants important...or will any do as long as it's glycol mixture? (forgive me if this is a dumb question.)
  6. Patrick Wong
    18,210
    6,511
    From Toyota service manual info:
    "Only use “Toyota Super Long Life Coolant†or similar high quality ethylene glycol based non-silicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology."
