Changing fog lights???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by suirp91257, Jul 26, 2010.
  1. suirp91257
    suirp91257 Junior Member
    33
    Indiana
    Whats the best way to go about changing the fog lights on a 2006 prius...one seems to have blown out and I was deciding on the best way to change it....Doesn't look real easy to get to..Any advice would help...Manual says could do damage to car if you try to change it yourself, can't be that hard is it...Thanks to all of you.
  2. kenmce
    kenmce High Voltage Member
    1,530
    507
    NY
    Changing the entire fixture, or just swapping out a bulb?
  3. macmaster05
    macmaster05 Senor Member
    4,050
    729
  4. suirp91257
    33
    Indiana
    replacing just the bulb, can't be that tough is it, Thanks
  5. fingas
    fingas Junior Member
    63
    Orange County
    There are 2 10mm bolts that you can remove from each side, under the fog light. Once those bolts are removed, you can easily pop out the plastic covering panel, and easily have access to reach in and change out the fog light bulb.
    I changed mine yesterday in less than 5 minutes. :rockon:
    Dino33ca likes this.
