Changing spark plugs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Grichard, May 25, 2011.
  1. Grichard
    Grichard Junior Member
    16
    florida
    I got the plugs for my '06. I hope to put them in in a day or 2. My question is: is it necessary to disconnect the 12v battery to do this? I've changed plugs in other cars without doing so. Thanks...Dick
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Not necessary
  3. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    You will not need to disconnect battery same as a regular car. You will just need a thin wall socket and extension.
  4. Hope McCloud
    Hope McCloud New Member
    Virginia
    I have a 2005 Prius and changed the plugs without disconnecting the battery. Got PROBLEM engine light and Hybrid Warning Light!!! Solution - disconnect and re-connect the battery - causing the computer to reset and the lights to go off. PS It also reset the back-up beep back to ON.
  5. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    Changed them on my '07 no problem.
    Don't need to disconnect battery, but you should have your car turned off (not ACC, not READY).
    No warning lights, worked just fine.
  6. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    The service manual says to disconnect, but it is not necessary. It is possible that the husband disconnected something else that was in the way and caused the problem. However, a happy ending nonetheless.
  7. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Most workshop manuals list disconnecting the battery negative as the first step in many procedures purely as a safety measure to prevent any possibility of the car being started while the work is being performed.
    Just switch the sks system off and have your keys in a safe place (other than the ignition).
