Changing the 12V battery on prius 2008
Discussion in 'Gen 2 Prius Main Forum' started by goudelas, Sep 3, 2018.
  1. goudelas
    goudelas New Member
    RO
    I got same sensor problems after I changed the 12V battery onmy prius 2 from 2008. On board appear the red triangle and the yellow motor. Can anyone help?! Thanks! 1535968786598.jpeg 1535968806624.jpeg
    VTR-L09 ?
    49,585
    welcome!
    if you know for sure that the new battery is fully charged, then your car has a more serious problem, and you will need tech stream to read the trouble codes.
    how many miles on her?
  3. PriusCamper
    PriusCamper Senior Member
    11,119
    4,529
    Pacific Northwest, USA
    Sometimes it takes a new replacement battery as much as 70 miles to settle down and stop throwing codes... Such as C1310 comes up alot after a rebuild or replace. Find out what the error codes are and report back, or google search this website to find an appropriate thread for your error code number.
    goudelas likes this.
  4. goudelas
    goudelas New Member
    RO
    I fix it by removing for 10 min the anode. Thanks guys!
    VTR-L09 ?
  5. bisco
    49,585
    well done!(y)
