Changing the air conditioner filter
Discussion in 'Gen 2 Prius Main Forum' started by jamarimutt, Apr 9, 2006.
  1. jamarimutt
    jamarimutt New Member
    985
    1. Open the lower glove compartment.
    2. Push in on the sides of the door until two notches disengage, the door will drop half way down.
    3. Locate a rod on the right side of the door and disengage it from a stub on the door.
    4. Pull the door and it'll come off.
    5. Look inside the hole and locate, near the top, a white rectrangular shelf.
    6. Pull on the sides and off comes a tray with the filter.
    7. Reverse the procedure after placing the new filter in the tray.
    The whole procedure takes two minutes and no tools are involved. I changed the filter at 36,000 miles and it was quire dirty.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yep, very easy, and waiting that long is way too long. Driving in Winnipeg city traffic I easily chuck it every 6 months. To filter out more of the dust and diesel soot, I went to Canadian Tire and purchased some of their "Supreme" furnace filters. These filters are rated MERV 12, the regular Toyota cabin filter is perhaps MERV 4. I cut them to fit but my interior is dust free.
    One of our more technical and helpful forum members, John 1701A, has a website full of helpful Prius tips:
    http://john1701a.com
  3. Ron Dupuy
    Ron Dupuy New Member
    112
    Fortuna, CA
    Is this the same as the "cabin air filter"?
  4. Tideland Prius
    16,445
    yeah.
    Thanks for the reminder! I'll go check at the end of the month. Haven't checked in a couple of months.
  5. BellBoy
    BellBoy Member
    220
    <div class='quotetop'>QUOTE(jamarimutt @ Apr 9 2006, 03:27 AM) [snapback]237103[/snapback]</div>
    What's the recommended miles/months to change it?
  6. benighted
    benighted New Member
    530
    Westport, WA
    <div class='quotetop'>QUOTE(BellBoy @ Apr 9 2006, 11:21 PM) [snapback]237419[/snapback]</div>
    Toyota reccomends every 10,000 miles. But at that rate I would be changing mine every 2 or 3 months!
  7. jamarimutt
    985
    My air filter gets fairly dirty at 18,000 miles, so perhaps 15,000 is a good mileage to change both filters.
  8. Tideland Prius
    16,445
    10,000 miles?!? at 10,000 kms/8 months, mine's as black as anything. Ugh.
  9. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    So how much does the cabin air filter cost? While getting my state inspection done today, the dealer offered to change my cabin air filter for $65 (on sale from $70). I declined. I figured that the air filter couldn't possibly cost anywhere near that much and I could save some money doing it myself.
    So... How much?
  10. glenk
    glenk Member
    109
    Fairfield, CA
    Does the cabin filter see both fresh and recirculated air flow or just recirculated as in my Honda?
    From the change interval that's been mentioned, it would seem that it sees all air flow.
  11. jamarimutt
    985
    I paid $20 for a Toyota factory filter. Judging from the presence of leaves and other debris, it evidently filters the air that enters the car. I don't'know if it filters recirculated air.
  12. Frank Hudon
    Frank Hudon Senior Member
    4,147
    just went out and pulled both of them and both are black. Put in the cleaned ones from last year and took the dirty ones down to the laundry room and gave them the Shout treatment and spun them dry and then Lysol'd them both, when dry will put them back in the box till next time. Diesel soot and bugs and leaves and only about 8 months.
  13. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Well I started out following the OEM directions. My conclusion it is much cleaner in Japan than here. I got the idea to change mine when I was complaining to an Allergist about how much trouble I was having. He asked if my car had a filter and I said yes and he advised me to change it. It made a huge difference and it was fifthly. It is worth it to me to change it with oil changes. I have particle and electrostatic filters in my house that I change and or clean more often than the car was getting changed and I have to say "just do it"
  14. Tideland Prius
    16,445
    Cdn$32.95++ up here.
    I can get a better filter (MicronAir Particulate) from Canadian Tire for $20++
  15. richard schumacher
    7,664
    1,043
    United States
    <div class='quotetop'>QUOTE(Frank Hudon @ Apr 10 2006, 10:06 PM) [snapback]237874[/snapback]</div>
    "Both"? You mean, the engine air filter and the cabin air filter? I thought it was bad luck to clean and re-use an engine air filter...
    [After reading Tideland's reply: "D'oh!!]
  16. Tideland Prius
    16,445
    he has a Classic and a Gen 2 Prius.
  17. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(Marlin @ Apr 10 2006, 01:50 PM) [snapback]237715[/snapback]</div>
    I bought 2 OEM filters on ebay for $15
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 11 2006, 04:21 PM) [snapback]238214[/snapback]</div>
    Jon:
    Would you happen to have a part number? I checked with a Cdn Tire on Fermor and also Portage west and they never heard of it. Thanks. Getting a bit tired of cutting one of their Supreme furnace filters to fit.
    jay
  19. tideland_raj
    tideland_raj New Member
    108
    Sunnyvale, CA
    <div class='quotetop'>QUOTE(jayman @ Apr 11 2006, 06:02 PM) [snapback]238247[/snapback]</div>
    Jay,
    Try this link http://www.micronair.us/Toyota/105
    I just googled for micronair particulate.
    Jon, is this the part that candian tire sells?
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(tideland_raj @ Apr 11 2006, 08:07 PM) [snapback]238320[/snapback]</div>
    Thanks. Will try it.
