Changing the Menu's language [JAPANESE]
Discussion in 'Gen 3 Prius Technical Discussion' started by Lucas Possamai, Jun 7, 2016.
  1. Lucas Possamai
    Lucas Possamai Junior Member
    25
    Auckland - New Zealand
    Hi guys,
    I've bought a Toyota Prius 2010 gen3, and it cames from japan (I'm living in New Zealand)
    The menu is in japanese and it does not have a English option.
    Do you guys know if there is anything I can do to translate it?
    cheers
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Greetings,
    As I understand it, there really is no way to change it from Japanese to English. You are not the first person to ask that question.
    Best of luck to you! (y)
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Yep, seems we get that question periodically from Pakistan too.
  4. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    If you can post pictures (or if anyone has a copy of the manual in Japanese) I can try and translate it for you. We get a lot of used JDM imports here too (and also in the UK).
