Changing tire size will effect with mileage
Discussion in 'Prius c Technical Discussion' started by mdalizyx, Dec 6, 2020.
  1. mdalizyx
    mdalizyx New Member
    Dhaka
    2016 Prius c
    Dear
    My car is - Toyota Prius c/Aqua 2016 model. Currently my car's tires size is 175/65/R15. But i want to use 195/45/R17 for sporty look.
    1. Does it reduce mileage?
    2. is there any others problem to change tires size?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Well it might change your "apparent" mileage that is displayed by the onboard computer .....and might make the actual mileage a bit worse as those will likely have more rolling resistance.
    I hope you realize that you will have to buy different WHEELS......as 17 inch tires won't fit on your 15 inch wheels.
    Then, the wider tires might rub something when turning sharply.
    Your idea of making a C more "sporty" made me grin.
  3. PriusWave
    PriusWave New Member
    16
    Los Angeles
    I don’t think you should do this. I believe it will make the tire speed sensor think something is wrong and throw codes.
  4. Leadfoot J. McCoalroller
    7,173
    6,720
    Pennsylvania
    2018 Prius c
    1. Likely, but not guaranteed.
    2. 45 series is pretty low. More prone to blowouts & rim breakage if you hit a large pothole. 195/45R17 is not a popular size, this could lead to a lot of waiting for replacements if something happens. This size will require wider rims than stock, and that means you might have a problem with rubbing- almost impossible to predict without a test fit.
    roadrunner likes this.
